查看: 777|回复: 31
Check Kingpin Latch Everytime You Head Out
 楼主| 发表于 2020-7-21 09:20:13 来自手机 | 显示全部楼层 |阅读模式
{"text":"Not my truck, I’m a new driver at Prime. Was taking a walk and heard this happen and stuck around for the tow trucks.  Red tractor in pic #1 is the guy who is having a bad day. You probably can’t see it in the picture, but the kingpin is not damaged. Pittston PA, July 19. ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":626.0,\"name\":\"\",\"url\":\"\",\"width\":834.0},{\"description\":\"\",\"height\":626.0,\"name\":\"\",\"url\":\"\",\"width\":834.0},{\"description\":\"\",\"height\":626.0,\"name\":\"\",\"url\":\"\",\"width\":834.0},{\"description\":\"\",\"height\":626.0,\"name\":\"\",\"url\":\"\",\"width\":834.0}]","canComment":true,"externalShare":false}
发表于 2020-7-21 10:36:38 来自手机 | 显示全部楼层
612134 发表于 2020-07-21 02:30:01 He should not had taken his thirty minute break at the pump and that would have never happened. lesson learned. ✔
","text":"If you really have an issue with it, man up and tell the driver something. Don’t be sis and pull crap like this. ","replyToPid":389790}
回复 支持 10 反对 4
发表于 2020-7-21 11:50:05 来自手机 | 显示全部楼层
612134 发表于 2020-07-21 02:44:33 I'll put locks on both of your back doors. ill get in your face and say something and ill pull your pin. learn to park in a spot to take your break. stay out of my way. Thanks. if it happens to you. it was me.
","text":"Lmao. Calm down super trucker. You’re a joke. ","replyToPid":389794}
回复 支持 8 反对 3
发表于 2020-7-21 10:44:33 来自手机 | 显示全部楼层
784919 发表于 2020-07-21 02:36:38 If you really have an issue with it, man up and tell the driver something. Don’t be sis and pull crap like this.
","text":"I'll put locks on both of your back doors. ill get in your face and say something and ill pull your pin. learn to park in a spot to take your break. stay out of my way. Thanks. if it happens to you. it was me.","replyToPid":389791}
回复 支持 6 反对 5
发表于 2020-7-21 10:30:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"He should not had taken his thirty minute break at the pump and that would have never happened. lesson learned. ✔","replyToPid":0}
回复 支持 5 反对 3
发表于 2020-7-21 13:20:10 来自手机 | 显示全部楼层
Haha okay old man. Go shave that nut sack hair off your face.
{"replyToPid":389808,"replyTo":"
784919 发表于 2020-07-21 04:59:31 Haha okay old man. Go shave that nut sack hair off your face.
","text":"omg im about to cry!! 😂 stfu you have no clue kid hahaha since I'm the old guy here. let me teach you a thing or two. Kid. always remember, be cautious when starting stuff with a guy that has nothing, because he has nothing to lose. You have no clue who you're talking to or starting with at truck stops and what mind set they're actually really in. It might just save your life. obviously you have never done any time. In a Rig or anywhere else for that matter. the more you keep your mouth shut and your ears open the longer you will live."}
回复 支持 4 反对 3
发表于 2020-7-21 12:47:53 来自手机 | 显示全部楼层
784919 发表于 2020-07-21 03:50:05 Lmao. Calm down super trucker. You’re a joke.
","text":"yeah. super trucker alright. that's you. youre the super trucker! in a truck that never stops with another guy in a rig 24/7 hats off to you! looks like you're the only real super trucker here haha would never catch me doing all that. Have you're team member show you how to park that rig so youre not parking at the pump sweetheart","replyToPid":389801}
回复 支持 3 反对 4
发表于 2020-7-21 12:59:31 来自手机 | 显示全部楼层
612134 发表于 2020-07-21 04:47:53 yeah. super trucker alright. that's you. youre the super trucker! in a truck that never stops with another guy in a rig 24/7 hats off to you! looks like you're the only real super trucker here haha would never catch me doing all that. Have you're team member show you how to park that rig so youre not parking at the pump sweetheart
","text":"Haha okay old man. Go shave that nut sack hair off your face. ","replyToPid":389806}
回复 支持 2 反对 4
发表于 2020-7-21 09:41:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"Not only visually check it but pull against your trailer often with the brakes set. ","replyToPid":0}
回复 支持 5 反对 1
发表于 2020-7-22 06:34:13 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Here's some rocket science to the new drivers 🙄\n Set trailer brakes 1st, pull forward until you feel a little tension on kingpin, pull tractor brakes, problem solved, nobody can pull your pin.\n1 exception, when temp gets below 25°don't pull trailer brakes at all, they will freeze and you'll be stuck in the morning 🤯"}
回复 支持 2 反对 2
发表于 2020-7-21 20:34:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"now what it somebody would of got hurt or killed because of this\nThink Think","replyToPid":0}
回复 支持 2 反对 2
发表于 2020-7-21 18:36:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"So... you're willing to commit another Felony because you're impatient? Sounds like you never should've left. \nAlthough, I do agree that people talk way too much.","replyToPid":0}
GMT+8, 2026-3-21 23:04 , Processed in 0.078653 second(s), 24 queries .
