查看: 319|回复: 10
Hello fellow drivers , at what RPM is safe to idle a truck when parked cuz of A/C. I’m doing it @700?!
 楼主| 发表于 2020-7-21 02:20:12 来自手机 | 显示全部楼层 |阅读模式
发表于 2020-7-21 08:15:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"The lowest RPM possible, optimally zero.","replyToPid":0}
发表于 2020-7-21 03:48:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"what engine? ISX Cummins 850 max.","replyToPid":0}
发表于 2020-7-21 09:05:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"I been told by my mechanics 700 rpm is just right!!","replyToPid":0}
发表于 2020-7-21 09:46:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"Cummins X-15 high idle at 900 rpms with the engine fan on. Keeps your oil pressure up. I do the same in winter minus the fan.","replyToPid":0}
发表于 2020-7-21 10:28:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Newer truck with DPF not required high RPM if you do HIGH RPM you will fill your filter ","replyToPid":0}
发表于 2020-7-21 12:29:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"1000","replyToPid":0}
发表于 2020-7-21 20:35:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"1800","replyToPid":0}
发表于 2020-7-22 01:11:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"650rpms for a pete 587.","replyToPid":0}
发表于 2020-7-22 06:29:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"my detroit came factory with a high idle switch ; and goes to 1,000 automatically when i click high idle; (NOT FOR A/c) but if i need to idle for a bit here and there ; cool turbo;  stuck at a train crossing; or anytime i know im gonna have to move too soon to shut it off its 1,000 for me","replyToPid":0}
GMT+8, 2026-2-6 16:05 , Processed in 0.078344 second(s), 24 queries .
