查看: 366|回复: 14
parking
 楼主| 发表于 2020-7-19 11:19:34 来自手机 | 显示全部楼层 |阅读模式
{"text":"anyone else hate sleeping at truck stops? I sleep on the off ramps as much as I could. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-7-19 16:54:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"Drive local, at the end of the day your in your own house, cook what ever you want to eat, shower in your own shower, sleep in your own bed with no other trucks surrounding you and no matter  what time of day I arrive home parking is guaranteed. Best of all, once I arrive to the yard I get in my vehicle and go anywhere I want with no limitations. Life is good. ","replyToPid":0}
回复 支持 6 反对 2
发表于 2020-7-19 13:09:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"I prefer rest areas myself, especially when the truck parking is in the back....less noise from the highway","replyToPid":0}
回复 支持 5 反对 1
发表于 2020-7-20 01:04:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"off beat mom and pop truck stops, and rural rest areas and ramps are all I do. Mostly to avoid other drivers. The best sleep I've had was on a rural on ramp surrounded by evergreens","replyToPid":0}
发表于 2020-7-19 11:37:48 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"yes, I have hit 5 mirrors this year, not to mention the constant humming and higher levels of carbon monoxide, PTSD from glimpses of naked hairy men, seeing people consume family sized potato bags solo."}
发表于 2020-7-19 12:16:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"I hate truck stops also. The noise, smell and congestion all make for a worse sleeping experience.  Although off ramps are only slightly better.  You get a lot of road noise from the highway and those that drive by you plus it’s a bit riskier.  I prefer rest areas.  They are generally quieter, cleaner and it’s an easy on and off.  ","replyToPid":0}
发表于 2020-7-20 09:36:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"Only bums sleep on ramps. ","replyToPid":0}
发表于 2020-7-19 13:02:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"That’s not safe place to park either I always go into a Truckstop if you have any problems you have some where to go ","replyToPid":0}
发表于 2020-7-20 01:40:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"mr. gummies!!!! you need to park that truck immediately!!! and go home. apply for a job at a youre local walmart. ask for the door greeter position. you may use my name as a reference. thank you","replyToPid":0}
发表于 2020-7-20 09:37:37 来自手机 | 显示全部楼层
816144 发表于 2020-07-19 04:53:52 I don’t think you guys are in the right line of work...
","text":"😆 my thoughts exactly 👌🏻 ","replyToPid":389572}
发表于 2020-7-20 01:11:06 来自手机 | 显示全部楼层
738306 发表于 2020-07-19 08:54:11 Drive local, at the end of the day your in your own house, cook what ever you want to eat, shower in your own shower, sleep in your own bed with no other trucks surrounding you and no matter  what time of day I arrive home parking is guaranteed. Best of all, once I arrive to the yard I get in my vehicle and go anywhere I want with no limitations. Life is good.
","text":"And have to deal with all the stuff that makes you avoid truck stops when you have to go to a terminal or slip seat. I had what most consider the best local job there is and had to work docks","replyToPid":389584}
 楼主| 发表于 2020-7-20 03:08:26 来自手机 | 显示全部楼层
937297 发表于 2020-07-19 17:40:55 mr. gummies!!!! you need to park that truck immediately!!! and go home. apply for a job at a youre local walmart. ask for the door greeter position. you may use my name as a reference. thank you
","text":"that's quite funny","replyToPid":389623}
GMT+8, 2026-2-13 09:20 , Processed in 0.067048 second(s), 24 queries .
