查看: 317|回复: 10
front end shaking
 楼主| 发表于 2020-7-19 09:10:16 来自手机 | 显示全部楼层 |阅读模式
{"text":"hey y'all - what causes front end shimmy, moving to shaking over time - 2015 Volvo. \nthx much for comments","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-7-19 09:26:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"Unbalanced tires","replyToPid":0}
发表于 2020-7-19 11:31:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"Unbalanced tires , out of alignment, or your tie rods could be bad","replyToPid":0}
发表于 2020-7-19 18:25:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"its a volvo lol","replyToPid":0}
发表于 2020-7-19 13:12:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"Could be many things....tires out of balance or out of round, frozen caliper, alignment. Had similar scenario to you back in Feb and the left steer rim was out of round","replyToPid":0}
发表于 2020-7-19 14:07:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes, I’d go with unbalanced ties. That’s the most likely cause. ","replyToPid":0}
发表于 2020-7-20 15:13:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"it's your king pins.. I had the exact same problem with my volvo. It would start to shake around the same speed yours is.","replyToPid":0}
 楼主| 发表于 2020-7-19 21:57:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"thanks so much everyone! on the way to the Shop. Safe travels!","replyToPid":389585}
 楼主| 发表于 2020-7-19 10:04:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"thanks so much for reply - the shaking (which was shimmying at first) occurs between 62-67mph and moreso with an empty or light trailer verses a heavy. WTF?","replyToPid":389558}
发表于 2020-7-20 00:12:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"It could also be a broken belt in a tire, king pins, broken wheel stud or a universal joint","replyToPid":0}
GMT+8, 2026-4-17 23:49 , Processed in 0.204672 second(s), 24 queries .
