查看: 211|回复: 9
Chrome tips?
 楼主| 发表于 2020-7-18 22:28:10 来自手机 | 显示全部楼层 |阅读模式
{"text":"So rookie question here, I'm aware. I've tried a few chrome polishes and find the same result.  Looks great, but lasts only a few days. Is there some way to make it last longer? Something ya'll use to seal it? Wax maybe? Same for the paint. Seen a few things online, but thought asking ya'll may be more actual, road tested advice. Feel free to raz me, but please throw me some tips while doing it. :p Thanks in advance. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-7-18 22:49:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"order Dura Coat polish and get there sealer.Best on the market and will last","replyToPid":0}
发表于 2020-7-19 02:07:43 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"you need the exercise, just keep polishing everyday."}
发表于 2020-7-19 02:29:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"dura coat is the best out there.","replyToPid":0}
发表于 2020-7-19 13:05:04 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Had a guy polish my rims and they came out better than new. Showed me what he used. A bar of jeweler's  rouge (solid bar, no liquid), bust it up and put that In a one gallon Jerry can fill with gas. Shake it well. Carpet cut into 4\" pieces. Pour bit of gas/rouge mix on carpet and scrub rim. Older the rim the longer it takes. Will see grime come out. After that clean rim and apply polish."}
 楼主| 发表于 2020-7-18 23:01:05 来自手机 | 显示全部楼层
56366 发表于 2020-07-18 14:49:37 order Dura Coat polish and get there sealer.Best on the market and will last
","text":"Thank you!!","replyToPid":389438}
 楼主| 发表于 2020-7-19 08:53:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks!","replyToPid":389448}
 楼主| 发表于 2020-7-19 08:53:58 来自手机 | 显示全部楼层
717220 发表于 2020-07-18 18:29:42 dura coat is the best out there.
","text":"Thanks!!","replyToPid":389505}
 楼主| 发表于 2020-7-19 08:54:55 来自手机 | 显示全部楼层
988175 发表于 2020-07-18 18:07:43 you need the exercise, just keep polishing everyday.
","text":"Indeed. I'll keep that in mind.","replyToPid":389502}
发表于 2020-7-20 04:31:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Zeypher pro 40 ","replyToPid":0}
GMT+8, 2026-2-13 09:14 , Processed in 0.110427 second(s), 24 queries .
