查看: 455|回复: 33
Are you a 1 or a 2? Personally I'm a 1. Your opinion? But remember opinions are like a$$holes. We all have one...
 楼主| 发表于 2020-7-18 22:01:57 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":1512.0},{\"description\":\"\",\"height\":3743.0,\"name\":\"\",\"url\":\"\",\"width\":2833.0}]","canComment":true,"externalShare":false}
发表于 2020-7-19 04:03:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"4. I don't wear a mask because I'm not a sheep.    \"Those who would give up essential Liberty, to purchase a little temporary Safety, deserve neither Liberty nor Safety\" Ben Franklin","replyToPid":0}
回复 支持 14 反对 4
发表于 2020-7-19 04:21:31 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I came from a country that stripped away freedom bit by bit until it became a socialist/communist country just like what's happening now. If you don't think that can happen in America, it can."}
回复 支持 11 反对 1
发表于 2020-7-19 02:06:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have a right to drive 100mph, but I yield that right for the greater safety of us all. I also yield other rights when neccessary because im not a republican tool bag, quanon nut job.","replyToPid":0}
回复 支持 2 反对 9
发表于 2020-7-19 05:39:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"I just don't wear a mask unless it's required. I'm not a blind sheep.","replyToPid":0}
回复 支持 7 反对 3
发表于 2020-7-19 04:10:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"always some dope trying to make everything political.","replyToPid":0}
回复 支持 9 反对 0
发表于 2020-7-19 06:29:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"FBI statistics: 275,000 Americans die of Medical Malpractice a year. 65,000 Americans die of opioid overdoses. so in total 340,000 Americans die at the fault of doctors alone. (opioids are prescribed by doctors) Where is the outrage? the ChuFlu is all a sham","replyToPid":0}
回复 支持 7 反对 2
发表于 2020-7-19 05:52:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"This question is a psychological question to get you to conform. That's why it was phrased without the option of, No I do not wear a mask. This is all a sham.","replyToPid":0}
回复 支持 4 反对 3
发表于 2020-7-19 05:52:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"If I’m asked, fine. I’ll put one on. Otherwise, no thank you. Point is, your personal health is your own responsibility first and foremost. If you’re that concerned, then by all means feel free to mask up!","replyToPid":0}
回复 支持 5 反对 1
 楼主| 发表于 2020-7-19 06:09:51 来自手机 | 显示全部楼层
884942 发表于 2020-07-18 20:03:02 4. I don't wear a mask because I'm not a sheep.    \"Those who would give up essential Liberty, to purchase a little temporary Safety, deserve neither Liberty nor Safety\" Ben Franklin
","text":"Seriously do you have to be such a twat waffle?! I could give two flying flips if you’re a sheep or not. It’s called an OPINION, you have to go all political and get on your soapbox. You wanna go there...alright...do you have a constitutional right to wear a mask?? The answer is NO. Under the 10th amendment, state governments have the primary authority to control the spread of dangerous diseases within their jurisdiction. And since you chose to quote one of America’s favorite LIBERAL phrases. You happened to spin it out of it’s accurate meaning ... it wasn’t about liberty but about taxes and the ability to raise money for defenses. I’m sure you’ll have some snarky rebuttal....tag you’re it🙃💋🤔😲","replyToPid":389512}
回复 支持 5 反对 1
发表于 2020-7-19 04:46:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"You do NOT have  the RIGHT to driver PERIOD!!!!  The issuance of a drvers / operator's license grants you the PRIVILEGE to operate a motor vehicle on the country's roadways. As such, PRIVILEGES can be revoked for certain and numerous reasons.  Please do not confuse RIGHTS (such as those mentioned in the Constitution), with PRIVILEGES granted by local authorities.","replyToPid":0}
回复 支持 3 反对 2
发表于 2020-7-19 04:07:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"https://www.youtube.com/watch?v=X29lF43mUlo","replyToPid":0}
GMT+8, 2026-2-10 18:53 , Processed in 0.091433 second(s), 24 queries .
