查看: 438|回复: 9
freightliner cascadia 2019
 楼主| 发表于 2020-7-15 00:30:42 来自手机 | 显示全部楼层 |阅读模式
{"text":"Howdy, \n\nCant figure it out why my cascadia showing me 30-40mpg which is wrong. any suggestions how to fix this on my own without dealer? ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-7-15 02:41:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"take the battery cables off leave off for about 1/2 hr and reset the system if that dont work then its screwed lol","replyToPid":0}
发表于 2020-7-15 02:48:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"Use a calculator ","replyToPid":0}
发表于 2020-7-15 03:41:53 来自手机 | 显示全部楼层
106326 发表于 2020-07-14 18:41:50 take the battery cables off leave off for about 1/2 hr and reset the system if that dont work then its screwed lol
","text":"Yeah, you r right.","replyToPid":388975}
发表于 2020-7-15 05:13:48 来自手机 | 显示全部楼层
","text":"Lmao.","replyToPid":388975}
发表于 2020-7-15 03:42:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just reset the system","replyToPid":0}
发表于 2020-7-15 05:17:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"change your settings from liters to gallons. that ill do it.","replyToPid":0}
发表于 2020-7-15 05:17:06 来自手机 | 显示全部楼层
 楼主| 发表于 2020-8-8 07:24:04 来自手机 | 显示全部楼层
368782 发表于 2020-07-14 21:17:03 change your settings from liters to gallons. that ill do it.
","text":"it is in US units","replyToPid":388999}
 楼主| 发表于 2020-8-8 07:24:12 来自手机 | 显示全部楼层
GMT+8, 2026-4-17 07:53 , Processed in 0.125220 second(s), 24 queries .
