查看: 184|回复: 3
battery cable for 3000w inverter?
 楼主| 发表于 2020-7-13 08:42:20 来自手机 | 显示全部楼层 |阅读模式
{"text":"will there be any fire hazard running 10ft of 1/0 wire from battery to 3000w inverter with a 300amp circuit breaker?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-7-13 11:33:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"I would put a fuse in as close to the battery connection as possible. that way if the wire does rub through somewhere it blows the fuse I stead of starting a fire. you can buy the fuse block for that size wire from Walmart or best buy and a 30 amp fuse should do.","replyToPid":0}
发表于 2020-7-13 22:21:54 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"nope. I have the exact same setup. DO NOT use a 30amp. 😬"}
发表于 2022-10-18 12:32:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"1/0awg ofc = 150a fuse","replyToPid":0}
GMT+8, 2026-3-21 03:36 , Processed in 0.726758 second(s), 23 queries .
