查看: 213|回复: 5
Inverter trounle
 楼主| 发表于 2020-7-12 00:04:42 来自手机 | 显示全部楼层 |阅读模式
{"text":"I have a 3000 watt inverter. I have positive cable to battery and negative cable to ground. When I try using a dual electric burner my inverter starts sending alarms saying there’s not enough volts. Inverter says I’m only using 48% of load. I can use either burner without causing an alarm but not both. Does anyone have any ideas for me? Thanks.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-7-12 02:16:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Wrong inverter for your burner. May require a pure sine. Also possible, you might have too small in gauge or too long battery connection. Both can cause voltage drops.","replyToPid":0}
 楼主| 发表于 2020-7-12 00:13:34 来自手机 | 显示全部楼层
966111 发表于 2020-07-11 16:12:47 sounds like a screwed up inverter.  Is it really old? If they are really old sometimes the screen starts to kind of not work so well I had a percolator and it is over 3000 Watts so it could just be a high drain burner
","text":"It’s a brand new inverter ","replyToPid":388587}
发表于 2020-7-12 00:12:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"sounds like a screwed up inverter.  Is it really old? If they are really old sometimes the screen starts to kind of not work so well I had a percolator and it is over 3000 Watts so it could just be a high drain burner","replyToPid":0}
发表于 2020-7-12 00:18:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"Could be a factory defect inverter   the first thing I would try was to take it back and exchange it for another one. if that's not possible I would go get an cheap ohmmeter and check the burner and the inverter.","replyToPid":0}
发表于 2020-7-12 03:09:06 来自手机 | 显示全部楼层
713759 发表于 2020-07-11 16:13:34 It’s a brand new inverter
","text":"If it's a brand new inverter, more than likely it didn't come with proper cords. The factory cords use minimum current and I am sure that they aren't as thick as you need.\nGo to a Love's. They carry the proper replacement power cords for a 3000 watt inverter. They cost $69.00\n(had to but one 2 months ago). I also have a 3000 watt and short of buying a new one, this fixed the issue I was having. \nAlso, if the wires aren't properly connected and grounded, it will not pull the power it is supposed to.","replyToPid":388588}
GMT+8, 2026-4-17 23:49 , Processed in 0.146075 second(s), 25 queries .
