查看: 149|回复: 3
Fuel pressure
 楼主| 发表于 2020-7-10 09:38:21 来自手机 | 显示全部楼层 |阅读模式
{"text":"Does anyone know of a simple way to test fuel pressure in a Detroit 60 series engine on a 06 Freightliner? ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-7-10 09:49:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"Find someone with the DDEC program. It will come up when you run diagnostics. Normal charge for hooking up the computer is about $100","replyToPid":0}
发表于 2020-7-10 12:06:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"pressure gauge...?","replyToPid":0}
发表于 2020-7-10 13:31:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"Plastic gears by fuel filter housing need replaced. They pump your fuel. ","replyToPid":0}
GMT+8, 2026-2-10 18:53 , Processed in 0.078523 second(s), 24 queries .
