查看: 70|回复: 0
2016 UTILITY 3000R
 楼主| 发表于 2020-7-10 08:13:07 来自手机 | 显示全部楼层 |阅读模式
TrailerThread
typeOfNeckV2:
carsV2:
liftgateV2: -
halfRoundV2: -
stingerV2: -
extendableV2: -
floorTypeV2:
flipAxleV2: -
frameTypeV2:
equipmentStatusV2:
statusDetailsV2:
acquisitionDateV2:
certifiedUsedV2: -
previousOwnerV2:
titleRequiredV2: -
titleReceivedV2: -
contractV2: -
forConsigmentV2: -
consignorV2:
roofTypeV2:
hydraulicTailV2: -
buttomLoadV2: -
vaporRecoveryV2: -
axleTypeV2:
pneumaticSizeV2:
compartmentsV2:
includeForkliftV2: -
{"text":"2016 Utility 3000R with Carrier X4 7500 reefer, Disc Brakes, Air Ride, Air Slide, Right Weigh Load Scale Gauge, Fuel Saving Skirts, Bendix Eversure 3030 Air Brake System, TABS-6 Advanced ABS with Roll Stability, Hendrickson Vented Axles, Meritor PSI Tire Inflation with Thermalert, Right Weigh Load Scale, Hendrickson ULTRAA-K Slider System with Zero Maintenance Dampening, Bendix Disc Brakes, Stainless Steel Corner Posts, UTM Barrier Design Double Swing Stianless Steel Diamond Pattern Rear Doors, Anti-Theft Tamper Proof Hardward, Recessed swing door holdback, Heavy Duty Extru Alum Wedge Type Rear Thershold w/4 Dock Board Guide Plates, Veritex Wall Lining, Grote Supernova and Trucklite series LED lights, Side Skirts, and more...","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0}]","canComment":null,"externalShare":false}
GMT+8, 2026-4-2 20:26 , Processed in 0.078288 second(s), 26 queries .
