查看: 66|回复: 0
WWE's The Undertaker retires
 楼主| 发表于 2019-1-28 16:02:54 来自手机 | 显示全部楼层 |阅读模式
{"text":"After a 28 year span of raising hell in the WWE, The Undertaker called it quits at Wrestlemania and said goodbye.\n\nThe rivalry between Undertaker and Roman Reigns was short, but it came with an explanation point on who's yard the ring was. \n\nThe match itself was a good one, but you could tell that Undertakers age was showing. He didn't have the strength to give Reigns a 'last ride', and when he tried to do his signature rising up from the dead taunt, his body collapsed. Reigns ended up defeating the Undertaker, and walked away emotionally. When the Undertaker got his wits back, he put on his coat and hat and started to exit the ring. He stopped, walked back to the center of the ring, removed his gloves, coat and hat, placing them neatly in the center, crying the whole time. When he did leave the ring he went straight to family that was there. Hugged someone and kissed his wife, again crying. As he walked backstage he acknowledged the crowds \"thank you Taker\" chants.\n\nAnyone who has ever watched the WWE knows who the Undertaker is, and if you missed Wrestlemania I urge you to watch it.","pics":"[]","canComment":true}
GMT+8, 2026-3-21 11:20 , Processed in 0.065914 second(s), 23 queries .
