查看: 347|回复: 13
34hr restart with TL of onions
 楼主| 发表于 2020-7-9 02:41:20 来自手机 | 显示全部楼层 |阅读模式
{"text":"im hauling onions from ca to ga on a flatbed will the onions rot due to me doing a 34hr ?( i dont need the 34 but i would like to stop and see a gf )\n\ntnx ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-7-9 07:12:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"why would you do a 34 on a load...TF is wrong with you and your planning...","replyToPid":0}
回复 支持 3 反对 4
发表于 2020-7-9 04:23:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"No you’ll be fine make sure you eat a couple every now and then ","replyToPid":0}
发表于 2020-7-10 09:58:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"I've hauled them before. no you shouldn't stop. they can not take the heat they will explode. that is why they want you to haul them during the day when it is the hottest. but good luck","replyToPid":0}
发表于 2020-7-9 19:36:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"hopefully you're not stopping in Texas, it will be over 100 degrees all this week","replyToPid":0}
发表于 2020-7-10 10:16:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yep you had better keep them moving. Especially during the daytime. ","replyToPid":0}
发表于 2020-7-13 04:08:38 来自手机 | 显示全部楼层
982720 发表于 2020-07-08 23:12:37 why would you do a 34 on a load...TF is wrong with you and your planning...
","text":"Because getting your peepee tickled is most important!!","replyToPid":388181}
发表于 2020-7-10 09:58:15 来自手机 | 显示全部楼层
发表于 2020-7-10 09:58:12 来自手机 | 显示全部楼层
发表于 2020-7-10 14:07:21 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I know they look really cool when they roll down the interstate at 70 mph. You know when they fall of the truck. "}
发表于 2020-7-11 01:05:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"everyone has a different answer. Gf can wait, if you have hours keep rolling","replyToPid":0}
 楼主| 发表于 2020-7-9 09:19:04 来自手机 | 显示全部楼层
963422 发表于 2020-07-08 20:23:06 No you’ll be fine make sure you eat a couple every now and then
","text":"thank u will do","replyToPid":388160}
GMT+8, 2026-2-13 11:04 , Processed in 0.095650 second(s), 24 queries .
