查看: 167|回复: 3
Portable a/c unit for bunk
 楼主| 发表于 2020-7-7 23:39:31 来自手机 | 显示全部楼层 |阅读模式
{"text":"Has anyone tried a portable a/c unit for their bunk? Wondering if it can work to save from having to idle. I've seen some battery powered that charge by USB and not sure they will be enough.  I've seen some larger units but not sure I want to add the weight or give up the space. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-7-8 05:01:42 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"thermo king has a battery Apu that works off solar and can run 10 hours on a charge."}
 楼主| 发表于 2020-7-8 05:49:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thank you! I'll check it out.","replyToPid":0}
发表于 2020-7-8 07:53:43 来自手机 | 显示全部楼层
846515 发表于 2020-07-07 21:49:37 Thank you! I'll check it out.
","text":"anything short of an APU, you might as well just go sit in Loves and take a nap. My APU has trouble keeping it cool with the curtains closed in the summer. These trucks are not very well insulated.","replyToPid":387988}
GMT+8, 2026-2-13 11:03 , Processed in 0.063079 second(s), 23 queries .
