查看: 106|回复: 1
unit restart will occur hp1
 楼主| 发表于 2020-7-7 06:41:47 来自手机 | 显示全部楼层 |阅读模式
{"text":"Why am I getting this error? In the middle of nowhere with reefer problem. Thank ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-7-7 09:33:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"high pressure in number 1 circuit. cure is probability not having coil clean. shut off unit and clean the upper coil  or a shop will acid clean the coil for you.","replyToPid":0}
GMT+8, 2026-2-6 14:27 , Processed in 0.066125 second(s), 24 queries .
