查看: 623|回复: 17
Tow bill, who pays
 楼主| 发表于 2020-7-2 23:23:32 来自手机 | 显示全部楼层 |阅读模式
{"text":"I'm new to owning my own truck and am leased to a company. The other day my customer told me to turn around in the lot next to them and I got stuck. I went in and told them and was told 2 others had gotten stuck and had to call a tow truck. Is the bill something I just have to pay and go on my merry way or should it be there's to pay? To me if I had just turned around there without permission I could see it being my own fault, but they said it was ok to turn around there knowing I could get stuck.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-7-3 00:56:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"If I told you it was okay to drive in oncoming traffic would you do it? ","replyToPid":0}
发表于 2020-7-3 00:41:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"The incompetent driver is responsible ","replyToPid":0}
发表于 2020-7-3 00:16:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"It probably should be theirs,  however good luck getting anything out of them. Also not a good business practice to go suing your (or the company you are leased on with) customers. Just try not to go to that customer anymore if you can avoid it, or remember not to use that lot to try and turn around in. Either way yo are most likely stuck with tow bill this time.","replyToPid":0}
禁止发言
发表于 2020-7-3 00:06:17 来自手机 | 显示全部楼层
发表于 2020-7-3 07:22:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"why would you go into a wet dirt lot","replyToPid":0}
发表于 2020-7-3 13:32:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"Sorry Bud!! Sounds like a personal problem... Chalk it up and always prepare for an exit route","replyToPid":0}
发表于 2020-7-3 17:12:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"What companies are you going too?  You would think that they’d want you to strap the load so there’s no (or less) chance of damage. \n\nAs far as directions in/out, I always ask for the shipping/receiving department and ask them for directions. DO NOT trust the person working the phones to think about low cleatances or no truck routes","replyToPid":0}
发表于 2020-7-3 09:08:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"These brokers and shippers are always telling me \"nobody else does that\" when I explain that per DOT this load must secured with  straps.  Receivers are notorious for lying to drivers about routes in and out and that the cleachy is compacted. \n\nYou got stuck in mud O/O so everyone is exempt because reasons and George.","replyToPid":0}
 楼主| 发表于 2020-7-3 21:45:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"That's basically what the owner of the company ended up saying. Said just pay it and move on.","replyToPid":0}
 楼主| 发表于 2020-7-3 21:42:55 来自手机 | 显示全部楼层
691234 发表于 2020-07-02 23:22:59 why would you go into a wet dirt lot
","text":"Lot wasn't wet. Was limestone graded lot. Couldn't see the soft spots.","replyToPid":387273}
发表于 2020-7-3 17:03:17 来自手机 | 显示全部楼层
766797 发表于 2020-07-02 16:11:17 you got stuck sorry but its yours fault .... NEWER trust NO ONE to tell you aahhh plenty others have done it with no problem...me personally I getting MORE suspicious when they say something like that..you're the CAPTAIN of yours boat..👍🇺🇲
","text":"If he had a boat, though, he wouldn’t need to worry about getting it stuck in the mud.  A sand bar, maybe","replyToPid":387240}
GMT+8, 2026-4-17 23:50 , Processed in 0.103304 second(s), 24 queries .
