查看: 312|回复: 11
ISX15
 楼主| 发表于 2020-7-2 19:22:34 来自手机 | 显示全部楼层 |阅读模式
{"text":"A friend of mine has a Cummings ISX15 that using 1 gallon of oil a week but the truck seems to run and pull great (little to no smoke).  Can anyone tell me what we might can look at to fix this problem?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-7-5 11:51:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"his screen name is BJ1","replyToPid":0}
发表于 2020-7-5 00:47:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"hahahahahha which has never happened! ! so in other words oil usage is never even something i look at or think about ","replyToPid":0}
发表于 2020-7-2 20:48:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"Gallon a week is not bad how many miles are you running a week maybe put some Lucas or STP in oil it might help did he happen to switch oil sometimes that causes problems ","replyToPid":0}
发表于 2020-7-4 13:06:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"Been around these things for 64 years. Never saw a Cummings engine. Owned several Cummins engines over the years though.","replyToPid":0}
发表于 2020-7-2 22:31:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"I had 2 international's with that engine. sold them both once they started throwing blow back. They started with that very same problem tho, gallon of oil a week.","replyToPid":0}
发表于 2020-7-2 23:31:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"there is a couple places the oil can be going half of them bad; half of them no big deal! ! i have some trucks that dont drip one speck of a drop between 15,000 mile oil change ; and some trucks that have to be a half gallon of oil thrown in every 3,000 miles ! ! every truck is different ! the weigh stations are out &&&@ people with little rubbed on air lines or a brake outa adjustment and $&@@ people log books; meanwhile there are people who have no business behind the wheel of any vehicle (really) even a four wheeler when they dont have basic basic understanding (not saying every driver has to be a freakin mechanic) of the basics of the overall truck and engine and which repairs need immediate get off the road and fix; and which things you can baby it home on  ","replyToPid":0}
 楼主| 发表于 2020-7-3 08:40:57 来自手机 | 显示全部楼层
{"replyToPid":387237,"replyTo":"
824549 发表于 2020-07-02 15:31:11 there is a couple places the oil can be going half of them bad; half of them no big deal! ! i have some trucks that dont drip one speck of a drop between 15,000 mile oil change ; and some trucks that have to be a half gallon of oil thrown in every 3,000 miles ! ! every truck is different ! the weigh stations are out &&&@ people with little rubbed on air lines or a brake outa adjustment and $&@@ people log books; meanwhile there are people who have no business behind the wheel of any vehicle (really) even a four wheeler when they dont have basic basic understanding (not saying every driver has to be a freakin mechanic) of the basics of the overall truck and engine and which repairs need immediate get off the road and fix; and which things you can baby it home on
","text":"Tks larrybob, but it doesn't drip any oil out of the engine its  clean n I have driven my truck behind my friend's truck n don't see any smoking so I was checking to see if anyone has any ideas what else it could be."}
发表于 2020-7-5 00:42:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"if there is NO. sweet coolant smell in your oil; and NO greasy oil residue in your coolant ; i would NOT worry about any oil USE  at all 2-4 gallons of oil per 15,000 miles oil change every single time i crank the engine after i sleep i check the oil; without a rag; rub it all in my fingers and smell for coolant sweetness; coolant check once before i leave the start of a trip; pit fingers in and check for greasiness oily residue feel ","replyToPid":0}
发表于 2020-7-5 00:46:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"especially if you have zero loss of power and pulling ! ! i never do any looking or screwing around untill the cost of oil  per oil change is more than the cost of a search and rescue repair ! ! id have to be wasting $800 - $1200 in oil before i went and did some mystery worrisome phantom repair if i had no loss of power; no oil in coolant, and no coolant in oil! !  ","replyToPid":0}
发表于 2020-7-5 00:48:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"and i like oil dripping out from the bottom here and there ; gets alllllll over gets to the drive and flings it every where and basically the 1-3 gallone per pil change trucks are perfectly rust proofed in my book; plus i pay $80 (grandfathered in rate) for rustproofing every year anyways; ","replyToPid":0}
GMT+8, 2026-4-17 23:49 , Processed in 0.111000 second(s), 24 queries .
