查看: 840|回复: 65
I don’t understand how the United States COVID-19 numbers can be so high?? Even higher than China’s numbers?
 楼主| 发表于 2020-7-1 10:59:43 来自手机 | 显示全部楼层 |阅读模式
发表于 2020-7-1 11:26:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"Incompetent leadership.","replyToPid":0}
回复 支持 6 反对 9
发表于 2020-7-1 19:13:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"\"\"\"\"Personally, I think we should be a lot more concerned how a group of virologist at Wolfang laboratory in China funded by globalist n Governments can take a virus from a bat wifh no chance jumping to humans and turn it into a killing machine unleashed upon the world....and no one held accountable.\"\"\"\"","replyToPid":0}
回复 支持 12 反对 1
发表于 2020-7-1 11:10:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"https://banned.video/watch?id=5efab695672706002f367a0a.  \nThe presumptive cases are multiples of any single case that tests.  \nFurthermore the PCR test has been declared effectively useless because it does not isolate the virus before determination.   The system is rigged to generate the most false positive test results as possible in order to achieve some justification to continue the narrative and fear mongering.  \n","replyToPid":0}
回复 支持 10 反对 2
禁止发言
发表于 2020-7-1 19:34:58 来自手机 | 显示全部楼层
回复 支持 9 反对 2
发表于 2020-7-1 19:31:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"population control. Wait till the next one in a year or so.  Just my personal opinion.","replyToPid":0}
回复 支持 9 反对 1
发表于 2020-7-1 17:01:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"It probably has to do more with the actual testing.  More than likely China does a lot less than here due to social statuses. I could be wrong though.","replyToPid":0}
回复 支持 7 反对 0
禁止发言
发表于 2020-7-2 20:28:12 来自手机 | 显示全部楼层
回复 支持 4 反对 2
发表于 2020-7-2 01:18:59 来自手机 | 显示全部楼层
回复 支持 3 反对 3
发表于 2020-7-2 01:19:06 来自手机 | 显示全部楼层
回复 支持 3 反对 3
发表于 2020-7-1 11:37:00 来自手机 | 显示全部楼层
665973 发表于 2020-07-01 03:10:48 https://banned.video/watch?id=5efab695672706002f367a0a.  \nThe presumptive cases are multiples of any single case that tests.  \nFurthermore the PCR test has been declared effectively useless because it does not isolate the virus before determination.   The system is rigged to generate the most false positive test results as possible in order to achieve some justification to continue the narrative and fear mongering.  \n
","text":"so you still believe Donald trump masks are not required.","replyToPid":386922}
回复 支持 1 反对 4
发表于 2020-7-1 20:05:29 来自手机 | 显示全部楼层
","text":"bing0","replyToPid":386922}
发表于 2020-7-1 20:34:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"China can forcefully lock down their citizens with minimal repercussions, add to that all the conflicting media reports and political environment in the US and it's not hard to believe at all","replyToPid":0}
GMT+8, 2026-4-18 00:01 , Processed in 0.168525 second(s), 25 queries .
