查看: 158|回复: 4
A/C Question
 楼主| 发表于 2020-6-30 06:36:34 来自手机 | 显示全部楼层 |阅读模式
{"text":"2006 Freightshaker with new condenser, high pressure switch,  low pressure switch,  and full of freon not blowing very cold!   Any suggestions on what I'm missing would be greatly appreciated!  System calls for 3.5 lbs of freon and that's what's in it! compressor is running too. \nthanks for any suggestions.   \nbe safe out there ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
禁止发言
发表于 2020-6-30 07:38:12 来自手机 | 显示全部楼层
 楼主| 发表于 2020-6-30 07:29:35 来自手机 | 显示全部楼层
147103 发表于 2020-06-29 23:08:26 I had same problem. My water control valve wasn’t cut heat off. Is your rear bunk blowing cold?
","text":"I do have the heater valves shut off to the whole truck as well. front and rear controls both off.  4 valves off in sll","replyToPid":386747}
 楼主| 发表于 2020-6-30 07:28:44 来自手机 | 显示全部楼层
","text":"rear bunk doesn't work however the lines going back under the truck are getting cool","replyToPid":386747}
禁止发言
发表于 2020-6-30 07:08:26 来自手机 | 显示全部楼层
GMT+8, 2026-2-11 01:59 , Processed in 0.098605 second(s), 24 queries .
