查看: 184|回复: 3
inverter question
 楼主| 发表于 2020-6-29 00:51:13 来自手机 | 显示全部楼层 |阅读模式
{"text":"will a 3000 watt power inverter power a 115volt air conditioner that puts out 8000btu? ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-6-29 01:59:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"8,000 BTU (300-350 sq. ft.) \n8,000 BTU = 10 AMPS continous and dedicated \n8,000 BTU = 2344.569 continuous Watts\n\nWhy don't you just put a steering wheel in a reefer instead?","replyToPid":0}
回复 支持 4 反对 2
发表于 2020-6-29 01:41:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"Also, if it isn't a pure sine inverter, it will likely affect the A/C. It might not start or run right.","replyToPid":0}
发表于 2020-6-29 01:45:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"that's a lot of amperage draw. I would not do that unless you know exactly what you are doing and even then I still wouldn't do it","replyToPid":0}
GMT+8, 2026-2-11 01:59 , Processed in 0.067884 second(s), 24 queries .
