查看: 348|回复: 11
Cascadia question
 楼主| 发表于 2020-6-26 10:44:27 来自手机 | 显示全部楼层 |阅读模式
{"text":"My top clearance lights are out. I wiggled the pigtail and they temporarily worked. If it is the fuse, I can't tell which fuse is for the clearance lights. YouTube not helpful.   Which fuse is for the clearance lights? ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-6-26 10:57:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"Of the come of & on when you wiggle the pigtail, it’s the connection, not the fuse. ","replyToPid":0}
回复 支持 7 反对 0
发表于 2020-6-27 06:29:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"The problem is not the fuse. The problem is you drive a Freightliner. ","replyToPid":0}
发表于 2020-6-26 20:37:21 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"sounds like a broken wire in the pigtail, it's common. get a new pigtail and try it. if it doesn't fix it, return it, you know it's not the problem"}
发表于 2020-6-27 04:01:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"it could be one of the pins in the plug on trailer","replyToPid":0}
发表于 2020-6-26 12:10:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"Correct it’s not a fuse","replyToPid":0}
发表于 2020-6-26 12:33:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"Try to lube up your power to the trailer with that electric grease. ","replyToPid":0}
 楼主| 发表于 2020-6-28 03:32:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"All good advice, my clearance lights are working, it turns out they only work after dark.  That one's  a rail splitter for sure.\nWasn't fuse, it was the pigtail.","replyToPid":0}
 楼主| 发表于 2020-6-28 03:36:22 来自手机 | 显示全部楼层
905859 发表于 2020-06-26 22:29:23 The problem is not the fuse. The problem is you drive a Freightliner.
","text":"Righttt... 😄🤦‍♂️","replyToPid":386338}
发表于 2020-6-27 05:59:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Take a small flat blade screwdriver and spread the pins out a little especially the top 3.  The pins on both sides of the vary top pin carriers the power for tail and clearance lights. ","replyToPid":0}
GMT+8, 2026-4-17 21:41 , Processed in 0.077440 second(s), 24 queries .
