查看: 306|回复: 8
Hey follow truckers, is it ok if someone uses different colors of clearance light other than amber ?
 楼主| 发表于 2020-6-24 08:58:02 来自手机 | 显示全部楼层 |阅读模式
{"text":"Some friends told DOT can pull you offer for that . ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-6-24 21:51:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"Look up Federal DOT lighting regulations. \nOnly red on rear most point of truck-tractor and the same on trailer. and only amber for anything forward of the rear of truck-tractor or trailer.","replyToPid":0}
发表于 2020-6-24 13:47:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes ,we can use only Red colour as reflection ,otherwise DoT will be pull you definitely ,","replyToPid":0}
发表于 2020-6-24 17:05:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"I do know for a fact u can't run red in va","replyToPid":0}
发表于 2020-6-24 17:06:35 来自手机 | 显示全部楼层
732658 发表于 2020-06-24 05:47:17 yes ,we can use only Red colour as reflection ,otherwise DoT will be pull you definitely ,
","text":"I got a ticket in va for running red","replyToPid":385849}
发表于 2020-6-24 21:56:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Any other color can only be used for OFF-ROAD show only.","replyToPid":0}
 楼主| 发表于 2020-7-2 22:40:08 来自手机 | 显示全部楼层
840064 发表于 2020-06-24 09:06:35 I got a ticket in va for running red
","text":"On the sides of your truck ?","replyToPid":385899}
发表于 2021-1-6 20:25:54 来自手机 | 显示全部楼层
973992 发表于 2020-07-02 14:40:08 On the sides of your truck ?
","text":"no","replyToPid":387222}
发表于 2021-1-9 10:23:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"go ahead.  see others doing it but old school and have had those tickets from various places.  so now I choose not and wonder y.  but as I watch dot and other law enforcement only pick and choose when to do the job they were hired to do","replyToPid":0}
GMT+8, 2026-2-7 11:57 , Processed in 0.073927 second(s), 24 queries .
