查看: 485|回复: 16
is this a common problem?
 楼主| 发表于 2020-6-20 22:42:05 来自手机 | 显示全部楼层 |阅读模式
{"text":"My coolant level sensor, on my Freightliner, keeps acting up and every month or so, it shuts my engine down while I'm on the highway. With the engine out and no power steering, I can see why people used to respect tuckers; you need to be a Paul Bunyan to steer the truck. It's very sad to see all these disgusting lazy truckers who think driving until they are a road hazard and risking other people's lives is hard work.\n\nBut anyone else getting this same problem? I unplug the sensor and drive until I stop, plug it back in and I'm good for another month. I'm suspicious of a grounding problem, because I have already replaced the sensor.","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":1512.0}]","canComment":true,"externalShare":false}
发表于 2020-6-21 06:58:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"how many times were you dropped on your head when you were a baby?","replyToPid":0}
回复 支持 9 反对 2
发表于 2020-6-21 11:40:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'll take a few minor electrical problems over 5mpg any day...","replyToPid":0}
回复 支持 3 反对 3
发表于 2020-6-21 12:02:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"You talk crāp and negative to everyone on here then you expect help diagnosing problems with your truck?","replyToPid":0}
发表于 2020-6-21 23:16:04 来自手机 | 显示全部楼层
976667 发表于 2020-06-21 04:02:23 You talk crāp and negative to everyone on here then you expect help diagnosing problems with your truck?
","text":"yes true he generalized and bunched all truckers together in a negative view. old saying don't bite the game that feeds u.","replyToPid":385418}
发表于 2020-6-21 22:07:49 来自手机
977528 发表于 2020-06-21 06:58:03 I don't think anyone is asking for help, it's called polling. 🤔🤷\n\nthis young marine sounds like he knows more about this job than you do about yourself.
","text":"I can pound a 4\" inch nail into a 2x4 with my penïs. I know myself much more than this toilet licker knows about trucking.","replyToPid":385421}
支持 3 反对 1
发表于 2020-6-21 22:15:28 来自手机 | 显示全部楼层
977528 发表于 2020-06-21 03:40:41 I'll take a few minor electrical problems over 5mpg any day...
","text":"You must not haul sensitive freight then if you care about fuel mpg all I care about is not breaking down had a regen truck fix on it a lot haul good freight don’t worry about fuel mileage ","replyToPid":385417}
发表于 2020-6-21 14:58:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"I don't think anyone is asking for help, it's called polling. 🤔🤷\n\nthis young marine sounds like he knows more about this job than you do about yourself.","replyToPid":0}
回复 支持 0 反对 3
发表于 2020-6-21 10:01:07 来自手机
{"replyTo":"","text":"go off and die l0ser","replyToPid":0}
支持 2 反对 1
发表于 2020-6-21 08:35:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"my 2019 my boss put new sensor spliced. it shut down on me. has a little play at male female connection.  we taped it tight to stay have now more movement tight now all good he is ordering a new sensor in mean time black electrical tape around it holds it tight connection no play. good luck","replyToPid":0}
发表于 2020-6-21 14:54:55 来自手机 | 显示全部楼层
{"replyToPid":385418,"replyTo":"
","text":"smh"}
发表于 2020-6-21 17:30:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"It happens to me also. Took it in to get it fixed and all they did was put tape around the sensor where the wires are located it helped but sometimes when’s is really windy I have to put new tape on it","replyToPid":0}
GMT+8, 2026-2-11 01:59 , Processed in 0.087973 second(s), 24 queries .
