查看: 174|回复: 6
Air pressure problems
 楼主| 发表于 2020-6-20 03:01:31 来自手机 | 显示全部楼层 |阅读模式
{"text":"My air pressure on ONLY rear tank won’t build pass 100 psi VOLVO D12.... please help if you know what’s wrong","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-6-20 06:24:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"simple. it's a Volvo. throw it in the nearest dumpster and get a real truck","replyToPid":0}
发表于 2020-6-20 09:27:45 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"definitely check the governor, I had my pressure safety valve go out, and my secondary tank would not get air. I had to replace the governor and it was $700.The pressure safety valve controls where the air goes, that's how they balance out. And the valve for the one on my truck was not serviceable, had to replace the whole governor."}
 楼主| 发表于 2020-6-20 10:29:40 来自手机 | 显示全部楼层
976667 发表于 2020-06-19 22:22:39 1. switch air lines to see if it is a gauge or cluster issue?\n2. check tank pressure sensor in footwell on firewall\n3. check secondary solenoids for leaks on xmember near rear of transmission \n4. check leveling valve cab  and suspension and all suspension components for leaks\nyou have a secondary side issue\nit may be one of the accessory components leaking.\n(soapy water in spray bottle)
","text":"Thanks ","replyToPid":385181}
发表于 2020-6-20 06:22:39 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"1. switch air lines to see if it is a gauge or cluster issue?\n2. check tank pressure sensor in footwell on firewall\n3. check secondary solenoids for leaks on xmember near rear of transmission \n4. check leveling valve cab  and suspension and all suspension components for leaks\nyou have a secondary side issue\nit may be one of the accessory components leaking.\n(soapy water in spray bottle)"}
发表于 2020-6-20 06:46:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s a Volvo. (Mic drop) goodnight!","replyToPid":0}
 楼主| 发表于 2020-6-20 03:23:34 来自手机 | 显示全部楼层
766797 发表于 2020-06-19 19:10:14 your air governor  needs calibration
","text":"Thanks ","replyToPid":385164}
GMT+8, 2026-2-6 16:05 , Processed in 0.053163 second(s), 24 queries .
