查看: 66|回复: 0
Fuel Filter Prob 07 14l detroit. Cold weather gelling the filter.
 楼主| 发表于 2019-1-28 15:53:44 来自手机 | 显示全部楼层 |阅读模式
{"text":"I work local in NY so its cold. 07 14l detriot fl century\n\nMonday it was below zero and fuel filter gelled up. It was done maybe 5k miles ago. Replaced fuel filter and 300 miles later it is full again. I have the water separator clear plastic that the filter sits inside. Isnt this supposed to be about half full?that's how it used to be. When it's full doesn't that mean the filter is plugged? I get my fuel from a major truck truck stop 81 Mexico ny\n\nIf water is in the fuel, will it work itself out during temps above freezing?","pics":"[]","canComment":true}
GMT+8, 2026-3-21 18:38 , Processed in 1.826305 second(s), 24 queries .
