查看: 214|回复: 15
Air Conditioning question
 楼主| 发表于 2020-6-19 07:59:06 来自手机 | 显示全部楼层 |阅读模式
{"text":"Would anyone be able to tell me why on my 2006 freightshaker the A/C compressor kicks on for approximately 15 seconds and off for 10 seconds at a time all the time!  Not really knowledgeable on A/C units!  I do know the system is full on freon and there are no visible leaks!  Also the clutch fan in the truck is inop and is constantly spinning at truck RPM at all times! I was told that could be a issue with A/C unit, but again, not very knowledgeable with A/C!  Thank you in advance for advice!  Be safe everyone!","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-6-19 10:27:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"High pressure switch is bad ","replyToPid":0}
发表于 2020-6-19 10:35:58 来自手机 | 显示全部楼层
674413 发表于 2020-06-19 02:27:30 High pressure switch is bad
","text":"Yup, I’d put money on it ","replyToPid":385033}
发表于 2020-6-19 15:08:19 来自手机 | 显示全部楼层
","text":"One of the sensors is probably bad, can't really tell without checking. AC systems have a low pressure cut off sensor, and high pressure cut off sensor, and a temperature sensor on the evaporator  to make sure it doesn't ice.","replyToPid":385033}
发表于 2020-6-19 11:42:36 来自手机 | 显示全部楼层
976667 发表于 2020-06-19 03:34:58 he says fan clutch not kicking on.\nI bet if he hooked up gauges he would see high pressure peg out and hpco shuts off compressor
","text":"he should get tacos and alcohol and think about it cuz that's what I'm doing. it solves every issue","replyToPid":385046}
发表于 2020-6-19 08:10:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"Check your fuse. Could also be a vapor lock.","replyToPid":0}
发表于 2020-6-19 11:17:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"it's cycling on and off. put gauges on it but most times it does that because you are low on refrigerant and you could have a leak or leaks and/ or the compressor is bad","replyToPid":0}
发表于 2020-6-19 11:34:58 来自手机 | 显示全部楼层
691234 发表于 2020-06-19 03:17:01 it's cycling on and off. put gauges on it but most times it does that because you are low on refrigerant and you could have a leak or leaks and/ or the compressor is bad
","text":"he says fan clutch not kicking on.\nI bet if he hooked up gauges he would see high pressure peg out and hpco shuts off compressor","replyToPid":385044}
发表于 2020-6-19 10:57:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"h00k up gauges and tell us the pressures!","replyToPid":0}
 楼主| 发表于 2020-6-19 08:30:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"a bad clutch in the A/C compressor is what you're saying?","replyToPid":0}
 楼主| 发表于 2020-6-19 08:21:46 来自手机 | 显示全部楼层
976735 发表于 2020-06-19 00:10:14 Check your fuse. Could also be a vapor lock.
","text":"all fuses and relays were replaced yesterday!  I forgot to mention that! appreciate the feedback tho","replyToPid":384993}
发表于 2020-6-19 08:23:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"Could also be a bad clutch. Just a note, the clutch is supposed to spin constantly while the motor is running. It only locks and runs the compressor when the a/c is turned on. That’s why I’m thinking a bad clutch 🤷🏻‍♂️","replyToPid":0}
发表于 2020-6-19 10:56:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"hook up gauges and tell us the pressures.\nI'm also thinking probably h/lpco","replyToPid":0}
发表于 2020-6-19 11:14:12 来自手机 | 显示全部楼层
976667 发表于 2020-06-19 02:57:45 h00k up gauges and tell us the pressures!
","text":"exactly. that's the very first thing to do","replyToPid":385041}
GMT+8, 2026-2-11 01:59 , Processed in 0.093193 second(s), 24 queries .
