查看: 51|回复: 0
2019 International? LT? Series
 楼主| 发表于 2020-6-18 00:13:07 来自手机 | 显示全部楼层 |阅读模式
mileageV2:
{"text":"LEASE MAINTAINED/TILT & TELE/BLOCK HEATER/FULL GAUGES/DUAL AIR RIDE SEATS/POWER HEATED MIRRORS/POWER WINDOWS & LOCKS/TAG AXLE/SET UP FOR OPTIMUN FUEL MILEAGE/COLLISON MITIGATION SYSTEM    2019 International® LT® SeriesInspired by drivers. Built for drivers.Features may include:BENDIX® WINGMAN® ADVANCED™Bendix® Wingman® Advanced™ collision mitigation comes standard on the LoneStar™. The standard solution gives drivers following distance and stationary object alerts and brings together adaptive cruise control with collision mitigation braking technology and the full-stability technology – Bendix ESP®.REMOTE DIAGNOSTICSOnCommand™ Connection allows fleet managers to remotely monitor more than 130 vehicle health checks. By spotting needed repairs early, you can avoid surprises and reduce unplanned service visits.ACCESS GRANTEDMany features of the LoneStar™ are designed for easy service. Bulbs can be replaced without tools. Interior fasteners are visible and accessible. The fuse panel is located in the passenger side dash for easy access. FUEL-EFFICIENT POWERTRAINIn partnership with Cummins® and Eaton®, the LT™ Series introduces the industry’s most fuel-efficient powertrain, SmartAdvantage™, with 7 percent better fuel economy* than other integrated powertrains.IMPROVED AERODYNAMICSWe improved the aerodynamic contours of the hood, fenders, wheel openings and chassis skirts. We minimized trim and sealed portions of the hood. A new aero-enhanced three-piece bumper and contoured pedestal mirrors complete the profile.EngineCummins X15 400 – 565 hp and 1,450 – 2,050 lb.-ft. torqueInternational A26 370 – 475 hp and 1,350 – 1,750 lb.-ft. torque TransmissionEaton® 9, 10, 13, 15, 18-Speed ManualEaton Cummins SmartAdvantage™ Powertrain 10-speed TransmissionEaton Fuller Advantage™ Series 10-speedEaton Ultrashift PLUS LSE 16-Speed TransmissionEaton UltraShift® PLUS 10, 13, 18-Speed Automated ManualAxlesFront: Hendrickson 12,000 - 14,000 lbs.Front: Meritor: 12,000 - 14,000 lbs.Front: Dana Spicer: 12,000 - 14,000 lbs.Single Rear Axle (4x2)Rear: Meritor: 23,000 lbs.Rear: Dana Spicer: 23,000 lbs. Tandem Rear Axle (6x4)Rear: Meritor: 40,000 - 46,000 lbs.Rear: Dana Spicer: 40,000 - 46,000 lbs.GVWR32,000 - 60,000 lbs.Cab/Sleeper Configurations56" Low Roof SleeperBBC125" BBC/50 BAAxle Configurations4x26x4 6x2Wheelbase146-226" 4x2160-252" 6x4","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":480.0,\"name\":\"\",\"url\":\"\",\"width\":640.0},{\"description\":\"\",\"height\":480.0,\"name\":\"\",\"url\":\"\",\"width\":640.0},{\"description\":\"\",\"height\":480.0,\"name\":\"\",\"url\":\"\",\"width\":640.0},{\"description\":\"\",\"height\":480.0,\"name\":\"\",\"url\":\"\",\"width\":640.0},{\"description\":\"\",\"height\":480.0,\"name\":\"\",\"url\":\"\",\"width\":640.0},{\"description\":\"\",\"height\":480.0,\"name\":\"\",\"url\":\"\",\"width\":640.0},{\"description\":\"\",\"height\":480.0,\"name\":\"\",\"url\":\"\",\"width\":640.0},{\"description\":\"\",\"height\":480.0,\"name\":\"\",\"url\":\"\",\"width\":640.0},{\"description\":\"\",\"height\":480.0,\"name\":\"\",\"url\":\"\",\"width\":640.0}]","canComment":null,"externalShare":false}
GMT+8, 2026-4-2 21:40 , Processed in 0.425672 second(s), 25 queries .
