查看: 392|回复: 13
truck hacks
 楼主| 发表于 2020-6-16 20:37:39 来自手机 | 显示全部楼层 |阅读模式
{"text":"Got a 2016 Cascadia. Opti idle isnt always the most reliable. Looking for a hack to override idle shutdown...\ntried several youtube videos but they didnt work on the '16. Its getting hot in Chicago! Thx. ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1512.0,\"name\":\"\",\"url\":\"\",\"width\":2016.0}]","canComment":true,"externalShare":false}
发表于 2020-6-17 04:54:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"release the tractor brakes problem solved. or what the old dinosaur said, same thing","replyToPid":0}
发表于 2020-6-17 01:44:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"had a 16 cascadia.  I taped a hot hands to the temp sensor.","replyToPid":0}
发表于 2020-6-16 22:29:44 来自手机 | 显示全部楼层
799612 发表于 2020-06-16 13:06:49 how to do parked regen when soot level is good but engine check light and stop engine red light pop up. 2020 cascadia.
","text":"can you read the codes from the dash?","replyToPid":384493}
 楼主| 发表于 2020-6-20 08:14:05 来自手机 | 显示全部楼层
750760 发表于 2020-06-16 13:38:30 Set cruise control to 850rpm. Basically turn truck on or leave on after you stop. Then hit cruise control to turn on, then hit set/accel to bring up rpms to around 850 or max, which is usually that much. Then you're set for as long as you have fuel. The truck will rev up further to complete regen when needed. On a side note that also saves your engine from cavitation and gelling. It'll take about a gallon per hour run at that setting, usually
","text":"ty. I read about this for the 2017 model. it does not work on my 2016 though.","replyToPid":384498}
 楼主| 发表于 2020-6-20 08:16:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"now that's a hack! awesome idea.","replyToPid":0}
发表于 2020-6-17 08:09:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"The tractor brake trick does not always work. This truck for example... breaks releases truck in gear stopped at a light. It will still shut down. The only solution I found is pressing on the accelerator. So remember those throttle sticks from the old days? Yep yep. Still works. ","replyToPid":0}
发表于 2020-6-16 22:29:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have heard the trailer brake only trick. I used to use a half bottle of 20 oz on pedal.","replyToPid":0}
发表于 2020-6-16 21:06:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"how to do parked regen when soot level is good but engine check light and stop engine red light pop up. 2020 cascadia.","replyToPid":0}
发表于 2020-6-16 21:38:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"Set cruise control to 850rpm. Basically turn truck on or leave on after you stop. Then hit cruise control to turn on, then hit set/accel to bring up rpms to around 850 or max, which is usually that much. Then you're set for as long as you have fuel. The truck will rev up further to complete regen when needed. On a side note that also saves your engine from cavitation and gelling. It'll take about a gallon per hour run at that setting, usually","replyToPid":0}
发表于 2020-7-11 07:54:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"my old company turned ours off, but I found a way around it. Not sure if yours has a menu to increase idle. if it does, just push the button and idle it higher. if your company was like mine, you push the button, release and then hold it down again.","replyToPid":0}
发表于 2020-6-17 04:14:59 来自手机 | 显示全部楼层
","text":"Yes my truck did that ended up doing 5 miles an hour it actually gave me a time when it was going to shut down I drove it 40 minutes past it wasn’t supposed to be running time but it eventually would only go 5 miles an hour there is a sensor in there on the passenger side I believe they had to work on the Polish guys know all these late model region garbage trucks","replyToPid":384493}
发表于 2020-6-17 04:16:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"Had an international like that could never get it to not shut down d ... thing always did that","replyToPid":0}
GMT+8, 2026-4-16 18:50 , Processed in 0.107203 second(s), 24 queries .
