查看: 403|回复: 10
How long is too long to take a nap on the fuel islands?
 楼主| 发表于 2020-6-14 09:20:46 来自手机 | 显示全部楼层 |阅读模式
{"text":"My friend says as long as I want if I put a do not disturb sign  with the time I will be waking up ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-6-14 22:26:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"yalllll only have these problems at the franchise big name places! ! i run 50% backroads and have not stopped on a main road name brand type truck stop in years! ! why not so your 30 minute stuff on the ON RAMP.... anyhow ? the fact that these questions even come up is further reason why i use mom and pop type truck stops!!! no modern losers; free coffee outa glass fresh perculator machines like homemade; as soon as they get allot of traffic and then renovate and then fill ip and become like the big names i stop going to them; ","replyToPid":0}
回复 支持 5 反对 1
发表于 2020-6-14 10:18:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"no more than ten hours. no less than five hours","replyToPid":0}
发表于 2020-6-14 10:36:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hope you're a sound sleeper. I'd feel bad if the sound of my hammer taking out your tail lights disturbes you. Its not easy being considerate but I try.","replyToPid":0}
回复 支持 4 反对 1
发表于 2020-6-14 09:52:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"I usually wait for mr sir to post about it on the forum then i wait another 30mins for my break.","replyToPid":0}
回复 支持 3 反对 2
发表于 2020-6-14 09:53:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"as long as that nozzle stays in your arse","replyToPid":0}
发表于 2020-6-14 10:15:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"so long as your door is unlocked, do what you want. If you need to lock your doors, you might want to evaluate why you're so afraid.","replyToPid":0}
发表于 2020-6-16 14:33:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"until somebody tells you to move I guess LOL. I usually prefer to a fix a placard to the rear of the offending Vehicles trailer :-)","replyToPid":0}
发表于 2020-6-14 11:43:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you don’t mind someone messing with your truck (pulling 5th wheel, braking a taillight, etc) then park there as long as you want. Otherwise, 10 minutes if busy or if it’s 1am then you can probably take your 30","replyToPid":0}
发表于 2020-6-14 10:32:50 来自手机 | 显示全部楼层
957589 发表于 2020-06-14 01:52:44 I usually wait for mr sir to post about it on the forum then i wait another 30mins for my break.
","text":"mr sir has many accounts..matter of fact he even commented on this post but you can't see 🤪","replyToPid":384151}
发表于 2020-6-14 09:36:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"you should be fine as long as you make sure do a good walk around of your truck with out getting out of your truck but the walk around is very important to make sure you don't get flat tires after moving and your trailer will be following you but you can't get out of your truck to do it because your going to have a lot of angry people around you.\n\nin my honest opinion you might just want to park to sleep","replyToPid":0}
GMT+8, 2026-4-17 23:25 , Processed in 0.141870 second(s), 24 queries .
