查看: 51|回复: 0
2014 UTILITY 3000R
 楼主| 发表于 2020-6-14 08:12:29 来自手机 | 显示全部楼层 |阅读模式
TrailerThread
typeOfNeckV2:
carsV2:
liftgateV2: -
halfRoundV2: -
stingerV2: -
extendableV2: -
floorTypeV2:
flipAxleV2: -
frameTypeV2:
equipmentStatusV2:
statusDetailsV2:
acquisitionDateV2:
certifiedUsedV2: -
previousOwnerV2:
titleRequiredV2: -
titleReceivedV2: -
contractV2: -
forConsigmentV2: -
consignorV2:
roofTypeV2:
hydraulicTailV2: -
buttomLoadV2: -
vaporRecoveryV2: -
axleTypeV2:
pneumaticSizeV2:
compartmentsV2:
includeForkliftV2: -
{"text":"2014 UTILITY 3000R CARRIER 2500A With 10,xxx HOURS,  Tire Inflation, Right Weigh Load Scale, Bendix TABS-6 ABS,  Hendrickson HKANT 40K Air Ride/Slider System,  Corrugated Side Panels, UTM Barrier Double Swing Rear Doors with Stainless Steel Diamond Pattern, Veristex Wall Liner, LED Lights and more. Trailer is Structurally sound and solid with no patches on the inside liner or roof but does have a cosmetic weld section in the floor that does not effect the integrity or functionality of the trailer.","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0}]","canComment":null,"externalShare":false}
GMT+8, 2026-4-2 23:11 , Processed in 0.067747 second(s), 25 queries .
