查看: 286|回复: 12
tint!
 楼主| 发表于 2020-6-12 20:42:24 来自手机 | 显示全部楼层 |阅读模式
GeneralThread
canComment:
{"text":"Are you allowed to have tinted windows on a commercial vehicle here in Texas?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-6-12 21:27:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"I've seen it, alot. but not sure of the laws. seems like a good reason to get pulled into a weigh station. in my opinion. starts with getting pulled in because of window tint. Next thing you know you're out of service for something else.","replyToPid":0}
回复 支持 6 反对 0
发表于 2020-6-13 08:19:38 来自手机 | 显示全部楼层
Yes, but only to a certain darkness. It is not dark enough to cool the inside of the truck. DMV office will know what percentage is allowed.
{"replyToPid":383186,"replyTo":"
109790 发表于 2020-06-12 18:43:08 Yes, but only to a certain darkness. It is not dark enough to cool the inside of the truck. DMV office will know what percentage is allowed.
","text":"You need a doctor's note saying you are sensitive to sunlight to get a DMV exemption, and if you're black, forget about it, police don't care about no doctor's note."}
发表于 2020-6-13 01:31:21 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"hahaha you're a joke. you think dot does a very quick superficial inspection? you're not even a driver. next thing youre going to tell me is nobody is ever even put out of service every single day hahaha youre funny 😂😂"}
发表于 2020-6-12 23:08:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"exactly","replyToPid":0}
发表于 2020-6-13 08:22:43 来自手机 | 显示全部楼层
612134 发表于 2020-06-12 17:31:21 hahaha you're a joke. you think dot does a very quick superficial inspection? you're not even a driver. next thing youre going to tell me is nobody is ever even put out of service every single day hahaha youre funny 😂😂
","text":"trucks put out of service are usually minor issues. logbook violations, inoperative lights, Worn breaks and tires. They don't check your accessory belt tension, they don't check emissions, They don't check almost anything to do with your engine, it's all things you can spot just by looking at your truck in the morning. and if you have any violations, you are a danger to the public and yourself.","replyToPid":383176}
发表于 2020-6-13 01:22:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"no.","replyToPid":0}
发表于 2020-6-13 12:05:12 来自手机 | 显示全部楼层
first off, it is brakes. not breaks. and yes I can see how no brakes can definitely be a minor issue. get outta here haha 😄 so do you crawl under your trailer every morning in January in Wyoming to check your breaks? haha
{"replyToPid":383276,"replyTo":"
612134 发表于 2020-06-13 02:29:39 first off, it is brakes. not breaks. and yes I can see how no brakes can definitely be a minor issue. get outta here haha 😄 so do you crawl under your trailer every morning in January in Wyoming to check your breaks? haha
","text":"good catch, you should be a DOT Inspector. And the short answer, yes I do.\n\nI do a full 132 point inspection every morning."}
发表于 2020-6-13 10:29:39 来自手机 | 显示全部楼层
973732 发表于 2020-06-13 00:22:43 trucks put out of service are usually minor issues. logbook violations, inoperative lights, Worn breaks and tires. They don't check your accessory belt tension, they don't check emissions, They don't check almost anything to do with your engine, it's all things you can spot just by looking at your truck in the morning. and if you have any violations, you are a danger to the public and yourself.
","text":"first off, it is brakes. not breaks. and yes I can see how no brakes can definitely be a minor issue. get outta here haha 😄 so do you crawl under your trailer every morning in January in Wyoming to check your breaks? haha","replyToPid":383263}
发表于 2020-6-13 02:43:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes, but only to a certain darkness. It is not dark enough to cool the inside of the truck. DMV office will know what percentage is allowed.","replyToPid":0}
发表于 2020-6-13 01:23:38 来自手机 | 显示全部楼层
612134 发表于 2020-06-12 13:27:27 I've seen it, alot. but not sure of the laws. seems like a good reason to get pulled into a weigh station. in my opinion. starts with getting pulled in because of window tint. Next thing you know you're out of service for something else.
","text":"If you can't pass a DOT inspection, I don't want you on the road. They do a very quick superficial inspection, something you should do every morning.","replyToPid":383125}
GMT+8, 2026-2-4 18:38 , Processed in 0.064777 second(s), 26 queries .
