查看: 262|回复: 8
CB Radio
 楼主| 发表于 2020-6-12 09:33:55 来自手机 | 显示全部楼层 |阅读模式
{"text":"what is the  best  cb for  a otr truck  driver ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-6-12 11:06:29 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"general lee is the best..make sure you peel the flag off"}
发表于 2020-6-12 10:52:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"A working one","replyToPid":0}
发表于 2020-6-12 11:37:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have a Cobra 29 LTD Classic. Been working well for 15+ years. ","replyToPid":0}
发表于 2020-6-15 10:17:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have a converted ranger B4 and works great. I can pick up those annoying idiots with base stations many 100's of miles away.\npay no attention to anyone who tells you that you need an 18 ft coax cable. its nothing but a tale. just enough from radio to antenna is all you need.","replyToPid":0}
发表于 2020-6-13 03:26:29 来自手机 | 显示全部楼层
945897 发表于 2020-06-12 01:44:13 Cobra 29 LX 🐍 \norder it online and save a few dollars over the rip off truck stops
","text":"Only $10 difference. ","replyToPid":382955}
发表于 2020-6-13 02:56:09 来自手机 | 显示全部楼层
A working one
{"replyToPid":382980,"replyTo":"","text":"agreed just make sure your antenna is good and you will get what you want out of it i use a Bearcat 880 cheap one from a shell truckstop works fine now that I put a good antenna on it"}
发表于 2020-6-12 14:45:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"i use a galaxy 77","replyToPid":0}
发表于 2020-6-12 13:17:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"Stryker.\nTwice what I ever thought I’d spend on one but I wish I’d done it long ago. ","replyToPid":0}
GMT+8, 2026-2-13 17:43 , Processed in 0.115263 second(s), 24 queries .
