查看: 354|回复: 4
Oops again
 楼主| 发表于 2020-6-11 19:44:22 来自手机 | 显示全部楼层 |阅读模式
{"text":"Not sure why he was trying to turn around here. But he should stay home or at least the four lane. ","videos":"[]","link":"{}","pics":"[{\"description\":\"Big oops\",\"height\":992.0,\"name\":\"\",\"url\":\"\",\"width\":744.0}]","canComment":true,"externalShare":false}
发表于 2020-6-12 07:57:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"That is definitely a notebook.","replyToPid":0}
发表于 2020-6-11 21:19:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"Also it looks like you have Elite Pass tolling. I drive a long hood Pete also. If you have problems with it reading like I did I ended up removing the transponder from behind the seal. I mounted that EZ pass transponder towards the top left corner of my passenger side windshield. I put the longer primary transponder towards the lower left corner of the same passenger side windshield. Works every time now.","replyToPid":0}
发表于 2020-6-11 21:53:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"just another bad decision","replyToPid":0}
发表于 2020-6-11 21:08:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"Never fails 😆 ","replyToPid":0}
GMT+8, 2026-2-13 17:43 , Processed in 0.072179 second(s), 24 queries .
