查看: 246|回复: 9
E
 楼主| 发表于 2020-6-11 13:05:52 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[]","link":"{}","pics":"[]","canComment":false,"externalShare":false}
发表于 2020-6-12 09:26:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"Eat once a day and watch the fat disappear! Drink water the rest of the day and take a multivitamin ","replyToPid":0}
发表于 2020-6-11 13:24:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"I started doing yoga and carrying some fitness  bands, as well as packing lunches helps a lot ","replyToPid":0}
发表于 2020-6-11 16:29:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"it just means you are finally getting paid well. congratulations","replyToPid":0}
发表于 2020-6-11 17:43:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"not the twinkies 😭😭😭","replyToPid":0}
发表于 2020-6-11 20:51:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"Twinkies? Where do you find Twinkies? They still make those huh","replyToPid":0}
发表于 2020-6-11 21:10:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"I personally recommend at least 2-3 bottles of Mt Dew per day 😆 ","replyToPid":0}
发表于 2020-6-11 22:50:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'm getting skinier on the road .  waisting my time at del and shiper non stop .hungry like a 🐕 right now ... im at del , then rush for pick up ..","replyToPid":0}
 楼主| 发表于 2020-6-12 04:44:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hahaha! Lol!","replyToPid":0}
发表于 2020-6-14 03:36:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"Eat a salad or something low carb once a day. Fat and protein are okay! Hormones are created when your body processes food and carbs produce the most hormones which then your body stores as fat cells by making insulin. If this process occurs less often, one would undoubtedly store fat less often. Stands to reason. Give it a try for a month and eat at about the same time of day. Consult a nutritionist and your physician. Results will vary but you should see improvement! Respond to this thread in a month and let’s see!","replyToPid":0}
GMT+8, 2026-3-21 01:14 , Processed in 0.118233 second(s), 24 queries .
