查看: 187|回复: 4
Trucking thru i80 winds
 楼主| 发表于 2020-6-11 03:39:45 来自手机 | 显示全部楼层 |阅读模式
{"text":"say gust blowing 40 mph, how fast is it safe to drive? speed limit is 80 mph. this week had some of the strongest winds I've drove thru. didnt see trailer tires off the ground ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-6-11 05:34:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"It also depends ","replyToPid":0}
回复 支持 0 反对 5
发表于 2020-6-12 00:37:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"https://i.redd.it/x5qmpxgpnh421.jpg\n\nwind chart for truckers. been pretty useful for me.","replyToPid":0}
发表于 2020-6-11 04:00:39 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"difference between average wind speeds and gusts. average can be low 30s with gusts over 40. you can roll through that. wind direction is another factor"}
发表于 2020-6-11 21:22:58 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Winds at 40mph I might pull in to a safe haven. Depends on how heavy the load is. Since I’m in a freight shaker, I’m probably doing 50-55 in that high of wind. Definitely not 60+\n\nBut at the end of the day if I’m impeding other traffic more than making efficient progress I’ll pull off."}
GMT+8, 2026-2-11 05:29 , Processed in 0.101720 second(s), 24 queries .
