查看: 403|回复: 7
2020 Cascadia CB issues
 楼主| 发表于 2020-6-10 23:43:22 来自手机 | 显示全部楼层 |阅读模式
{"text":"So I heard that the Cascadia has a terrible CB antenna. My question is, is it that bad? Or maybe I should get a external mount and antenna and be over with? If you have one, what's the best set up in your opinion?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-6-11 02:33:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"the problem is not the antenna. It is a matter of Grounding plain for you SWR's. FrtLiner is not the worst-case of all trucks, but grounding the radio and antenna is key. A separate/external setup could help but you are still fighting the same problem, SWR. Any CB shop should be able to help you but, I recommend Bob I80x70 PA. They will fix everything for a good price.","replyToPid":0}
发表于 2020-6-11 09:32:43 来自手机 | 显示全部楼层
回复 支持 0 反对 4
发表于 2020-6-11 08:09:34 来自手机 | 显示全部楼层
952329 发表于 2020-06-10 19:42:47 Never mind, I figured out. thanks for the help.
","text":"Please, inform the rest of us of your fix. I have the same truck and issue. ","replyToPid":382645}
 楼主| 发表于 2020-6-11 03:17:45 来自手机 | 显示全部楼层
256848 发表于 2020-06-10 18:33:32 the problem is not the antenna. It is a matter of Grounding plain for you SWR's. FrtLiner is not the worst-case of all trucks, but grounding the radio and antenna is key. A separate/external setup could help but you are still fighting the same problem, SWR. Any CB shop should be able to help you but, I recommend Bob I80x70 PA. They will fix everything for a good price.
","text":"do you know the fix? I heading out tomorrow and who knows when I'll go by a shop. I'm pretty handy given the right instructions.","replyToPid":382615}
 楼主| 发表于 2020-6-11 03:42:47 来自手机 | 显示全部楼层
952329 发表于 2020-06-10 19:17:45 do you know the fix? I heading out tomorrow and who knows when I'll go by a shop. I'm pretty handy given the right instructions.
","text":"Never mind, I figured out. thanks for the help.","replyToPid":382619}
 楼主| 发表于 2020-6-11 21:07:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"Basically it will depend on how good your radio is and if it's calibrated correctly. If you don't know how to calibrate a radio go to YouTube. Ther are plenty of examples there. Just make sure your SWR is below 2 (1.5 or below preferably) and you're good. Use channels 1 and 40 to do this. Just don't go cheap on your radio. get a good one with calibration on it.","replyToPid":0}
发表于 2020-9-29 10:19:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"get external antenna","replyToPid":0}
GMT+8, 2026-4-17 07:53 , Processed in 0.128777 second(s), 24 queries .
