查看: 57|回复: 0
problem. help pls
 楼主| 发表于 2020-6-7 22:07:12 来自手机 | 显示全部楼层 |阅读模式
{"text":"doing my pre trip at the yard, check oil and looks clear, I start the truck n not even 7 mins starts leaking from the antifreeze/water compartment, I turned it off. I see the floor and looks like oil. I put more water because I saw that some water was gone n it never fills up. I started the truck again and this happened. any tips on the problem will help. thanks","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":980.0}]","canComment":true,"externalShare":false}
GMT+8, 2026-4-17 12:44 , Processed in 0.083285 second(s), 23 queries .
