查看: 408|回复: 20
Old or new
 楼主| 发表于 2020-6-3 05:55:10 来自手机 | 显示全部楼层 |阅读模式
{"text":"I am torn between two trucks. Maybe y’all can help. I have a chance to buy a 93 379 pete fresh rebuild on a 3406b, no rust and inside is in great shape. Or I can get a new 389. I don’t know what to pick. I love old trucks and want to keep the legacy alive. Nothing like the sound of them. New trucks have the comforts. Any ideas out there","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-6-3 18:01:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'd take 93 anyday of the week over a 389 just to get away from the eld","replyToPid":0}
发表于 2020-6-3 09:28:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"you believe that a truck build in 1993 doesn't have rust I. 2020, I have a bridge I'd like to sell you.","replyToPid":0}
回复 支持 1 反对 3
发表于 2020-6-3 10:38:40 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"For what I do I’d want the 1993"}
发表于 2020-6-4 01:38:24 来自手机 | 显示全部楼层
815642 发表于 2020-06-03 17:10:14 washed it every other day just to go get some groceries at the store
","text":"truckers don't even wash themselves every other day, stop with the whale of a tale.","replyToPid":380793}
发表于 2020-6-3 20:45:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"Myself I would take the 93. The 93 you probably would have to spend a little money on in the beginning to get it right,,,unless there are receipts to show work had been done. If you don't know how to do work or have the ability to work on it yourself,,the 93 will be a little harder to find a good ol school mechanic to fix it. I personally drive a 93 with a 3406b. I do everything from rebuilding the motor to changing lights myself. I get between 5.5 and 6.5 mpg depending on what I'm hauling and the area I'm in,,,,I know some super trucker is gonna say I'm lying but I have records to prove lol.","replyToPid":0}
发表于 2020-6-3 23:21:25 来自手机 | 显示全部楼层
114671 发表于 2020-06-03 12:55:33 This truck was barn kept one owner. It was washed ever other day. Farmer has it. He is getting out of farming.
","text":"I bet it wasn't, even Pete on Pete, who loves his truck more than anything, doesn't wash his truck every other day. You're talking to a good salesman...","replyToPid":380685}
 楼主| 发表于 2020-6-3 20:52:19 来自手机 | 显示全部楼层
676405 发表于 2020-06-03 12:45:49 Myself I would take the 93. The 93 you probably would have to spend a little money on in the beginning to get it right,,,unless there are receipts to show work had been done. If you don't know how to do work or have the ability to work on it yourself,,the 93 will be a little harder to find a good ol school mechanic to fix it. I personally drive a 93 with a 3406b. I do everything from rebuilding the motor to changing lights myself. I get between 5.5 and 6.5 mpg depending on what I'm hauling and the area I'm in,,,,I know some super trucker is gonna say I'm lying but I have records to prove lol.
","text":"Thanks I have been around trucks most of my life and I can work on them with no problem. ","replyToPid":380683}
发表于 2020-6-3 21:30:19 来自手机 | 显示全部楼层
114671 发表于 2020-06-03 12:52:19 Thanks I have been around trucks most of my life and I can work on them with no problem.
","text":"if you can work on it,,,dont hesitate get the 93,,,,cheaper to maintain and alot less down time","replyToPid":380684}
发表于 2020-6-30 11:38:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hey just curious did buy that 93 Pete you was lookin at awhile back?","replyToPid":0}
发表于 2020-6-4 08:27:21 来自手机 | 显示全部楼层
969317 发表于 2020-06-03 01:28:49 you believe that a truck build in 1993 doesn't have rust I. 2020, I have a bridge I'd like to sell you.
","text":"truck built in 1993: still running.. \ntruck built in 2012: in the history books for a pile of crap, falling apart, dried out piece of plastic.....\n\n🤔","replyToPid":380594}
发表于 2020-6-3 12:28:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s depend on what you really like ","replyToPid":0}
 楼主| 发表于 2020-6-3 20:55:33 来自手机 | 显示全部楼层
","text":"This truck was barn kept one owner. It was washed ever other day. Farmer has it. He is getting out of farming. ","replyToPid":380594}
 楼主| 发表于 2020-6-3 20:56:07 来自手机 | 显示全部楼层
959279 发表于 2020-06-03 00:23:14 93.\nunless your a whiney millennial toilet licker,that needs the truck to shift for you.\nif you dont get the 93 show pics  and info for someone else who might want it
","text":"Thanks","replyToPid":380556}
 楼主| 发表于 2020-6-3 20:56:17 来自手机 | 显示全部楼层
766797 发表于 2020-06-03 00:48:22 you should pick base on what rate you believe to get the 3406b will bite chunk of your profits you can't do nothing about it.  Its mechanical so count between 4.5 to 5.5 MPG
","text":"Thanks","replyToPid":380566}
GMT+8, 2026-2-10 18:57 , Processed in 0.106906 second(s), 24 queries .
