查看: 350|回复: 10
How do I know what exits are blocked ?
 楼主| 发表于 2020-6-2 06:58:21 来自手机 | 显示全部楼层 |阅读模式
发表于 2020-6-2 18:32:25 来自手机 | 显示全部楼层
发表于 2020-6-2 08:15:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"waze app.\nor Google map click traffic filter on","replyToPid":0}
发表于 2020-6-2 10:15:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"if ya feel a bump then it was probably blocked by protesters if not then sits open. either way your good to go","replyToPid":0}
发表于 2020-6-2 09:43:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"Like mello jello said, google maps. Best gps  by far but lacks truck routing so use in tandem with atlas. Atlas is 30$ or so and google maps is free but uses data. Google maps has so many resources in its design that it makes any other gps look like an etch a sketch ","replyToPid":0}
发表于 2020-6-2 10:44:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"Look for the cop cars blocking them? Those are the ones with the flashy red n blue lights... 😂","replyToPid":0}
发表于 2020-6-2 10:19:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"Curfew go to bed","replyToPid":0}
发表于 2020-6-3 13:45:45 来自手机 | 显示全部楼层
538758 发表于 2020-06-02 02:15:50 if ya feel a bump then it was probably blocked by protesters if not then sits open. either way your good to go
","text":"😆","replyToPid":380303}
发表于 2020-6-6 00:08:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"read the sign","replyToPid":0}
发表于 2020-6-8 06:39:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"you will never know","replyToPid":0}
GMT+8, 2026-4-16 18:50 , Processed in 0.098224 second(s), 24 queries .
