查看: 728|回复: 34
Do you Tip on Takeout food orders?
 楼主| 发表于 2020-6-2 05:50:24 来自手机 | 显示全部楼层 |阅读模式
{"text":"Just picked up food at Denny's and the waitress replied \"whatever \" to my Thank you gesture 🥴","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":595.0,\"name\":\"\",\"url\":\"\",\"width\":1080.0}]","canComment":true,"externalShare":false}
 楼主| 发表于 2020-6-2 20:05:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"I only tip if I sit there and eat..not on takeout orders","replyToPid":380414}
回复 支持 8 反对 1
 楼主| 发表于 2020-6-2 22:42:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"you tip flying j when you pick up pizza slice?","replyToPid":380446}
回复 支持 4 反对 1
发表于 2020-6-2 19:55:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'll just go to the nearest 5 or 10 dollar.","replyToPid":0}
回复 支持 4 反对 1
发表于 2020-6-3 09:18:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"I've never tipped on takeout. \n\nand what's this 10 to 15% for bad service? I'm sorry, you don't get a tip for bad service. I'm not going to reward bad behavior","replyToPid":0}
发表于 2020-6-3 04:32:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"wow you people have never worked a day in restaraunts! your rude and have no sense! 1$ on buffet, stay home and learn to cook.","replyToPid":0}
发表于 2020-6-2 22:35:56 来自手机 | 显示全部楼层
723315 发表于 2020-06-02 13:13:46 I agree.  with the covid-19 its different,  most where out of work for a while.  that being said,  I don't tip for take out and only leave a dollar at a buffet.  it's a gratuity.  showing gratitude  for GOOD  service.  I don't tip bad, rude, lazy service.
","text":"This is wrong on so many levels smh ","replyToPid":380437}
回复 支持 1 反对 3
发表于 2020-6-2 21:13:46 来自手机 | 显示全部楼层
915763 发表于 2020-06-02 12:42:55 Me too, but when this pandemic started, I started tipping on takeout because I knew the person serving me was probably hurting for money. Unless it is a restaurant where the owners are the only ones working.
","text":"I agree.  with the covid-19 its different,  most where out of work for a while.  that being said,  I don't tip for take out and only leave a dollar at a buffet.  it's a gratuity.  showing gratitude  for GOOD  service.  I don't tip bad, rude, lazy service.","replyToPid":380436}
 楼主| 发表于 2020-6-2 20:18:34 来自手机 | 显示全部楼层
649124 发表于 2020-06-02 10:30:21 Dude...even before all this crap!I always even out the bill...to the waitress!...
","text":"I thought you only tip when you Dine in...when they actually serve you 🤔","replyToPid":380417}
发表于 2020-6-2 20:42:55 来自手机 | 显示全部楼层
953080 发表于 2020-06-02 12:18:34 I thought you only tip when you Dine in...when they actually serve you 🤔
","text":"Me too, but when this pandemic started, I started tipping on takeout because I knew the person serving me was probably hurting for money. Unless it is a restaurant where the owners are the only ones working.","replyToPid":380432}
发表于 2020-6-2 18:30:21 来自手机 | 显示全部楼层
回复 支持 2 反对 2
发表于 2020-6-2 17:36:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hello","replyToPid":0}
发表于 2020-6-2 17:41:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hahahaha but did u tip?","replyToPid":0}
发表于 2020-6-2 19:15:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes","replyToPid":0}
GMT+8, 2026-4-16 18:50 , Processed in 0.083703 second(s), 24 queries .
