查看: 211|回复: 7
how do you Negotiate freight rates and what things do you need to get a load off of a load board?
 楼主| 发表于 2020-6-2 01:46:33 来自手机 | 显示全部楼层 |阅读模式
{"text":"nobody talks about the basics anymore","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1224.0,\"name\":\"\",\"url\":\"\",\"width\":1632.0}]","canComment":true,"externalShare":false}
发表于 2020-6-2 09:36:24 来自手机 | 显示全部楼层
969317 发表于 2020-06-02 00:29:03 Let me write you a through response.
","text":"The etiquettes of negotiating freight rates is simple. Post which have rates are fixed, do not call unless you want to run that load for that rate. Just as you wouldn't walk into Walmart and negotiate prices of items, you do not call a broker who has a rate posted and try to haggle. If there isn't a posted rate, have at it, most likely you will get the shorter end of the stick because they haggle for a living, and expect to be lied or misled.\n\nHow do you haggle profitably? That is another art of survivor. Buy my book for 4 easy payments of $19.99. And I will explain the art to you in graphic details, so that you can become a millionaire as a solo truck driver.","replyToPid":380273}
发表于 2020-6-2 09:51:42 来自手机 | 显示全部楼层
255377 发表于 2020-06-02 01:49:46 Partner with a local shipper, thereby cutting out the carrier and the broker. It’s a win/win, the shipper pays less because the driver/carrier doesn’t charge as much because they don’t have to support middlemen.
","text":"we are the carrier... what are you talking about?","replyToPid":380291}
发表于 2020-6-2 05:55:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"etiquettes?","replyToPid":0}
发表于 2020-6-2 08:29:03 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Let me write you a thorough response."}
发表于 2020-6-2 09:49:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"Partner with a local shipper, thereby cutting out the carrier and the broker. It’s a win/win, the shipper pays less because the driver/carrier doesn’t charge as much because they don’t have to support middlemen. ","replyToPid":0}
发表于 2020-6-3 02:56:52 来自手机 | 显示全部楼层
","text":"local shippers are all scared to work directly with carriers or owner operators. there is a belief in America that everything has to be done through a broker. I've talked directly to shippers and they all say\" I don't know man, I don't wanna get in trouble with the broker\", as if I don't have the same insurance as the broker does in case something were to go wrong","replyToPid":380291}
发表于 2020-6-3 04:17:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"it is just easier for the shippers to give loads to the brokers to do all the legwork. Finding a qualified,  safe, legal carrier.  Takes all the responsibility off them.","replyToPid":0}
GMT+8, 2026-2-13 19:23 , Processed in 0.078706 second(s), 24 queries .
