查看: 312|回复: 9
Atlanta GA
 楼主| 发表于 2020-6-1 23:57:44 来自手机 | 显示全部楼层 |阅读模式
{"text":"Anybody knows if the 285 in Atlanta open or is it blocked because the protest? any information will help please. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-6-2 02:30:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"it was open yesterday, i went through there on the way to Knoxville.  No protests at that time, but that may have changed today.  Wish i could be of more help.","replyToPid":0}
发表于 2020-6-2 06:59:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"I don’t but where can I find out which ones are ? Stressing out since this world has gone crazy ","replyToPid":0}
发表于 2020-6-3 18:24:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"if they are protesting on 285 they wouldn't have a chance to make it back home the way them idiots drive down there. you would think they was on the Atlanta motor speedway","replyToPid":0}
发表于 2020-6-2 00:34:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"Should be open is the bypass for ATL","replyToPid":0}
 楼主| 发表于 2020-6-2 01:03:41 来自手机 | 显示全部楼层
528948 发表于 2020-06-01 16:34:17 Should be open is the bypass for ATL
","text":"I appreciate it the info.","replyToPid":380127}
发表于 2020-6-2 02:08:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"Wide open ","replyToPid":0}
 楼主| 发表于 2020-6-2 04:34:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"thank you guys for the info.","replyToPid":0}
 楼主| 发表于 2020-6-2 07:18:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"I just took the bypass. it was open. didn't see anything crazy.","replyToPid":0}
 楼主| 发表于 2020-6-7 00:31:22 来自手机 | 显示全部楼层
717220 发表于 2020-06-03 10:24:31 if they are protesting on 285 they wouldn't have a chance to make it back home the way them idiots drive down there. you would think they was on the Atlanta motor speedway
","text":"you got that right.","replyToPid":380673}
GMT+8, 2026-2-11 08:58 , Processed in 0.116607 second(s), 24 queries .
