查看: 247|回复: 6
Any hog haulers on here?
 楼主| 发表于 2020-5-30 09:23:53 来自手机 | 显示全部楼层 |阅读模式
{"text":"heading out to Minnesota to get hogs for the first time.\nI have been trucking for 20 yrs. I have never done livestock. \nI will be teaming to n.y. just looking for tips,tricks.\ndouble decker hog trailer. 160-180 hogs I believe.\nthanks","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-5-30 10:24:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"I hauled livestock for about 10 years. You won’t feel market hogs so much. When you load fat cattle you’ll feel it. When it comes to loading/unloading keep your cool. Especially with cattle. The farmers appreciate it. Also when loading cattle be sure to load the top first. Load the bottom last. That way the counterbalance in the nose works properly. Make sure your turning corners in the low side. Keep air moving on those hogs. If you need to stop and catch a nap make sure you do it in open air not between other trucks in a truck stop. I’ve taken many a nap on an on-ramp when I needed it. Good luck.","replyToPid":0}
发表于 2020-6-2 11:24:57 来自手机
支持 1 反对 0
 楼主| 发表于 2020-5-30 09:28:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"Haha any hippies try this I will not stop either. https://youtu.be/1t3hYPDgES4","replyToPid":0}
 楼主| 发表于 2020-5-30 09:51:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"no it's still work in progress needs some TLC yet","replyToPid":379170}
 楼主| 发表于 2020-5-30 09:39:12 来自手机 | 显示全部楼层
766797 发表于 2020-05-30 01:33:51 sorry  no livestock on Dinosaurs fleet 🇺🇲👍
","text":"no problem thanks","replyToPid":379164}
 楼主| 发表于 2020-5-30 10:30:39 来自手机 | 显示全部楼层
{"replyToPid":379192,"replyTo":"
956792 发表于 2020-05-30 02:24:23 I hauled livestock for about 10 years. You won’t feel market hogs so much. When you load fat cattle you’ll feel it. When it comes to loading/unloading keep your cool. Especially with cattle. The farmers appreciate it. Also when loading cattle be sure to load the top first. Load the bottom last. That way the counterbalance in the nose works properly. Make sure your turning corners in the low side. Keep air moving on those hogs. If you need to stop and catch a nap make sure you do it in open air not between other trucks in a truck stop. I’ve taken many a nap on an on-ramp when I needed it. Good luck.
","text":"thanks for the tips. I'm excited. it's new for me always wanted to try livestock hauling.\nrunning team so should be 20 hrs nonstop."}
发表于 2020-5-30 22:00:53 来自手机 | 显示全部楼层
962976 发表于 2020-05-30 02:30:39 thanks for the tips. I'm excited. it's new for me always wanted to try livestock hauling.\nrunning team so should be 20 hrs nonstop.
","text":"Best job you will get plenty of help from other haulers not like freight haulers don’t be afraid to ask 40 years of doing it","replyToPid":379195}
GMT+8, 2026-2-11 09:05 , Processed in 0.071179 second(s), 24 queries .
