查看: 1312|回复: 19
hello I need some help or advice?
 楼主| 发表于 2020-5-29 23:45:04 来自手机 | 显示全部楼层 |阅读模式
{"text":"I pick up a load from pepsi going to GA from MD. Due to covid I  was not allowed in the building to see them load the truck long story short the loader  load the truck with no air bags to stop the pallets from moving side to side he put air bags on the last two pallets so from the back of the trailer it looks like its load properly well after you take the first 2 pallets off the whole load shifted to one side pepsi is trying to make me pay for the lumpers to fix the load i refuse to so my question is what can I do legally? ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":1512.0},{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":1512.0}]","canComment":true,"externalShare":false}
发表于 2020-5-30 01:47:57 来自手机 | 显示全部楼层
966745 发表于 2020-05-29 17:40:37 don't listen to this guy, who cares if the doors were opened, you're not jumping in and looking at how it was loaded from the front.
","text":"Actually don’t listen to this tool.\nIf you closed the doors the driver is 100% responsible for his or her load.\n\nIt is like when getting an inspection at customs or the DOT.\n\nIf there is a load shift and there is damage to the cargo the first thing one of the fore mentioned asks is “who put the seal on the trailer”? \n\nIf you answer the shipper, all fault is taken from you the driver and put back on the shipper.\n\nYou won’t have a claim against your insurance and the company doesn’t take a hit on their safety score.\n\nNow if the driver closes the doors and installs the load locks it is without a doubt “100% the driver’s fault and actions can be taken towards the driver.\n\nThe person above that commented on my reply is obviously not a trucker and has no clue about the industry.","replyToPid":379000}
回复 支持 12 反对 0
发表于 2020-5-30 01:02:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have a question for you.\n\nDid you close the doors on your trailer or were the doors already closed and sealed?\n\nIf you closed the doors, you are 100% at fault.\n\nIf the doors were closed and there was a seal on the trailer, then it is 100% the shippers fault.\n\nSo ask your self the the questions mentioned above and you can actually take charge of your situation ","replyToPid":0}
回复 支持 8 反对 2
发表于 2020-5-30 00:47:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"straps?  airbags? nobody else does that!  yeah, well we do, so do it. It's all on the shipper, not the carrier. file the claim and inform the broker that that shipper is irresponsible sible and negligent","replyToPid":0}
回复 支持 9 反对 0
发表于 2020-5-30 02:25:14 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"powderfoot your right about that. if you can see the load and you close the door its on the driver. ive had to manny ill loadings. now i take pictures of the load. if i dont like it or it worries me il cantact dispatch/broker and make a fuss out of it and il note it on bols. (inproper loading by shipper. but i wont shut doors till i cover my rear. (some loads you just  cant see how they were loaded)"}
回复 支持 7 反对 1
发表于 2020-5-30 01:40:37 来自手机 | 显示全部楼层
966479 发表于 2020-05-29 17:02:31 I have a question for you.\n\nDid you close the doors on your trailer or were the doors already closed and sealed?\n\nIf you closed the doors, you are 100% at fault.\n\nIf the doors were closed and there was a seal on the trailer, then it is 100% the shippers fault.\n\nSo ask your self the the questions mentioned above and you can actually take charge of your situation
","text":"don't listen to this guy, who cares if the doors were opened, you're not jumping in and looking at how it was loaded from the front.","replyToPid":378991}
回复 支持 3 反对 5
发表于 2020-5-30 00:49:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"and bill thebroker/shipper for the lumper service!!!","replyToPid":0}
回复 支持 7 反对 0
发表于 2020-5-30 04:38:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"powderfoot2 is right. I've pulled enough Pepsi loads,  every Wednesday and Friday.  that's how they are normally loaded and every load I've ever pulled from Pepsi has stated that 2 load straps or load locks.  you have to close and seal the doors if your not comfortable about it back back to the dock and refuse to leave until it's correct.","replyToPid":0}
回复 支持 6 反对 0
发表于 2020-5-30 02:06:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"It is the drivers responsibility to make sure his or her load is loaded correctly when you strapped it you should have checked the load and made them fix it pay the lumper and learn a lesson ","replyToPid":0}
回复 支持 4 反对 2
发表于 2020-5-30 01:51:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"write shipper load and count on the bills, that's what JB Hunt had me do.","replyToPid":0}
回复 支持 5 反对 1
发表于 2020-5-30 00:26:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"looks like you were going around corners too fast. lol","replyToPid":0}
回复 支持 4 反对 1
发表于 2020-5-30 00:42:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"They can get it off they’ll have to take the Fort lift and shift the pallet for it to go to the site that is not leaning then they pull it out enough for someone to get on the side of it and push it over once they leaned over and you’ll have to hold it taking it off the truck you should not have to pay for that if that’s the case you need to call your company OS and D","replyToPid":0}
GMT+8, 2026-2-4 18:38 , Processed in 0.101699 second(s), 24 queries .
