查看: 244|回复: 7
APU question.
 楼主| 发表于 2020-5-28 01:38:55 来自手机 | 显示全部楼层 |阅读模式
{"text":"Putting a APU allows 400lbs. Is that 400 towards the GVW or just drive axles?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-5-30 10:34:13 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"technically it's not 400lb, it's the CERTIFIED weight of the APU, and you need to have a copy of the certificate to show dot if they ask."}
发表于 2020-5-28 03:53:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you have a APU you are legal to way 400 pounds over gross ","replyToPid":0}
发表于 2020-5-28 01:47:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Both","replyToPid":0}
发表于 2020-5-28 22:17:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"except California. California gives no extra. every other state you can way 80400lbs gross as long as the extra 400 is over the drive axles","replyToPid":0}
发表于 2020-6-1 06:42:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"Goes to your drive axles and GVW","replyToPid":0}
发表于 2020-5-28 02:22:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"I am still never overweight, just don't weight 400 lb yourself.","replyToPid":0}
 楼主| 发表于 2020-5-28 04:52:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks for the info guys, appreciate it","replyToPid":0}
GMT+8, 2026-4-18 01:36 , Processed in 0.090837 second(s), 24 queries .
