查看: 53|回复: 0
Transmission woes
 楼主| 发表于 2020-5-26 07:35:46 来自手机 | 显示全部楼层 |阅读模式
{"text":"My freightliner cascades called it a day. It’s stalling in the first three gears and stuttering and jumping 4 through 8. Upper gears work fine. Downshift is fine. It’s hard for the dealer to fix because they don’t test drive with trailers. Since it’s lower gears it’s more a load bearing issue. Bobtail you’re don’t use those first three and even can skip 4 or 5. The last time it did it I was able to manually shift but the manual shift wouldn’t work either and I got parked on the interstate because the distance alert kept seeing an imaginary object at 3 ft. My other theory is this is a fire me truck. I guess my bf will be happy if I get sent home. Always good when you please a veteran, right? I’m so frustrated. Of course it’s Memorial Day so it isn’t fixed. What is this????","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
GMT+8, 2026-4-17 14:25 , Processed in 0.057080 second(s), 23 queries .
