查看: 414|回复: 18
Going into New York
 楼主| 发表于 2020-5-26 00:01:32 来自手机 | 显示全部楼层 |阅读模式
{"text":"I got a load going into the Bronx I know I can get on George Washington bridge but does anyone know if we’re allowed on the Manhattan or Brooklyn bridge and the FDR, want to do a little sight seeing although I won’t stop anywhere just drive through since never been, ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-5-26 00:10:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"First time ever u will not won't to go back a today being a holiday have fun with it","replyToPid":0}
禁止发言
发表于 2020-5-26 00:10:16 来自手机 | 显示全部楼层
发表于 2020-5-26 00:46:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"Stay off of parkways in NYC area. Just follow your signs/be alert.. you will do just fine. I’m in the area myself today.\n\n🇺🇸🇺🇸🇺🇸","replyToPid":0}
发表于 2020-5-26 00:10:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"Are you looking for baez in ny?","replyToPid":0}
发表于 2020-5-26 04:37:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"Make sure  you  stay  on EXPRESSWAYS that is the truck routes","replyToPid":0}
 楼主| 发表于 2020-5-26 02:26:21 来自手机 | 显示全部楼层
956792 发表于 2020-05-25 16:46:57 Stay off of parkways in NYC area. Just follow your signs/be alert.. you will do just fine. I’m in the area myself today.\n\n🇺🇸🇺🇸🇺🇸
","text":"Thank you ","replyToPid":377515}
发表于 2020-5-26 00:30:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can’t go on the Brooklyn bridge the Manhattan bridge is right next to it to take via fdr ","replyToPid":0}
禁止发言
发表于 2020-5-26 00:11:50 来自手机 | 显示全部楼层
发表于 2020-5-26 00:57:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you have ez pass it will work on GW bridge or pay 100 dollars I think it is. That was few years ago since I did that but find spot park lock your truck take uber or lyft to avoid making your rig convertible. Good luck driver","replyToPid":0}
 楼主| 发表于 2020-5-26 02:26:06 来自手机 | 显示全部楼层
459313 发表于 2020-05-25 16:57:56 If you have ez pass it will work on GW bridge or pay 100 dollars I think it is. That was few years ago since I did that but find spot park lock your truck take uber or lyft to avoid making your rig convertible. Good luck driver
","text":"Thanks","replyToPid":377516}
GMT+8, 2026-4-17 21:43 , Processed in 0.124507 second(s), 24 queries .
