查看: 526|回复: 24
New logs rules
 楼主| 发表于 2020-5-23 16:41:56 来自手机 | 显示全部楼层 |阅读模式
{"text":"Like breaks in the fuel line weren’t bad enough. Now EVERY driver will break in the fuel lane. It’s going to take two hours to fuel. Can’t the regulators just GET OUT of my life??? ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-5-23 16:58:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"Calm down.","replyToPid":0}
回复 支持 5 反对 1
禁止发言
发表于 2020-5-23 19:42:34 来自手机 | 显示全部楼层
发表于 2020-5-23 19:51:57 来自手机
{"replyTo":"","text":"Well for one they were already doing that.  The 30 minute break change is good!  You can go ON DUTY for 30 minutes to satisfy your required 30 minute break.  That mean that you can go on duty while you're fueling and still get your break in.","replyToPid":0}
支持 1 反对 1
发表于 2020-5-26 08:14:29 来自手机 | 显示全部楼层
966551 发表于 2020-05-25 21:44:09 and your boy friend likes this👍when you are behind him with your hands around is waist as he drives your moped.
","text":"when you respond everyone knows you are nothing but i fat,stinky,lazy,cross dresser that drives a peterbuilt who wants to show off..Pos little man..wow 90 inch sleeper..i bet you have your midget pole in there so your boyfriend can watch your short looser body go up and down the pole and hus pole.","replyToPid":377580}
发表于 2020-5-26 05:37:54 来自手机
966551 发表于 2020-05-25 21:13:39 then you are one of the ignorant drvers that does a fu break on the fuel Island. Get a job rookie
","text":"Lol....rookie? I have more miles running the roads than you do running your mouth,  little girl.","replyToPid":377574}
支持 0 反对 1
发表于 2020-5-26 05:35:17 来自手机
966551 发表于 2020-05-25 21:15:08 wow..big mouth just like on thr cb,get a job little man
","text":"He said get a job....lmfao.  Your comment sounds less like a witty comeback and more like fear lolololol","replyToPid":377575}
支持 0 反对 1
发表于 2020-5-26 05:13:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"then you are one of the ignorant drvers that does a fu break on the fuel Island. Get a job rookie","replyToPid":377440}
发表于 2020-5-24 11:51:17 来自手机
629603 发表于 2020-05-23 22:50:43 When did that happen?\nOr when is it going into affect?
","text":"https://www.businessinsider.com/fmcsa-changes-eld-hos-laws-that-truck-drivers-hate-2020-5","replyToPid":376988}
支持 1 反对 0
发表于 2020-5-24 10:32:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"I run a pre e log truck and don’t run a log book, I don’t have that problem ","replyToPid":0}
发表于 2020-5-23 21:56:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"out of you life and into my pants high five","replyToPid":0}
发表于 2020-5-23 20:36:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"remember with the change you will only need to do your break before 8 hrs driving not just on duty time. that helps a lot in my opinion","replyToPid":0}
发表于 2020-5-24 06:50:43 来自手机 | 显示全部楼层
965656 发表于 2020-05-23 11:51:57 Well for one they were already doing that.  The 30 minute break change is good!  You can go ON DUTY for 30 minutes to satisfy your required 30 minute break.  That mean that you can go on duty while you're fueling and still get your break in.
","text":"When did that happen?\nOr when is it going into affect?","replyToPid":376870}
发表于 2020-5-25 13:25:44 来自手机 | 显示全部楼层
965656 发表于 2020-05-24 03:51:37 Same here...6 old dinosaurs.
","text":"30 minute break in the fuel Island?check your 5th wheel and air hoses,you park there doing a fu break,you deserve the consequences","replyToPid":377058}
发表于 2020-5-26 05:15:08 来自手机 | 显示全部楼层
965656 发表于 2020-05-25 06:44:41 Go ahead and do it. Blue 1994 379 Pete w/90 inch bunk, has a Harley Davidson plaque on both sides of the sleeper. There's two chrome eagles on the back of the whale tail (no, I'm not talking about your wife)  right beside the 2 eagles are 2 wide angle security cameras pointing down.  Was running robots down to Mexico and didn't want any Southern domicile invasive relocation specialists hiding up under the whale tail, so be careful,  pull my fifth wheel and that would be the last thing hard you grasp with your girlish hands.  \n\nYou sound like a dòùchè on here by the name of love the dames, better know as lòvès the dìcķ.  You could change your name to that from your unimaginative default one.  \n\nHave a nice day, ltd.
","text":"wow..big mouth just like on thr cb,get a job little man","replyToPid":377443}
GMT+8, 2026-4-17 23:26 , Processed in 0.115358 second(s), 24 queries .
