查看: 345|回复: 21
need help with 2017 Volvo VNL 780
 楼主| 发表于 2020-5-22 14:30:33 来自手机 | 显示全部楼层 |阅读模式
{"text":"hey guys, i am looking into a used 780 D13 engine with 500K miles on it and not sure if it is a good decision. if you own one please leave me your input, i would really appreciate an honest answer from someone who owns one right.\n\nheard that the injectors and cups give issues and also tons of I-Shift transmission issues. last thing we need now a days is a dead weight to lose more. \n \n\nthanks","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":980.0,\"name\":\"\",\"url\":\"\",\"width\":2016.0},{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":980.0}]","canComment":true,"externalShare":false}
发表于 2020-5-22 21:24:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"No. and if it has a Volvo engine fück no.","replyToPid":0}
发表于 2020-5-23 01:30:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"great engine and transmission","replyToPid":0}
发表于 2020-5-23 21:48:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"great engine and transmission just upgrade the fan module and delete def .","replyToPid":0}
发表于 2020-5-25 11:37:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"I would also have them pull an ECM report on that truck to see how many parked regens and other issues that particular truck has had.","replyToPid":0}
发表于 2020-5-25 11:35:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"The report the one driver referred to is a Rig Dig report that is like a CarFax report. They have been known to have injector cup problems just like you referred to. The only problems that I've seen with the IShift transmission is if you don't keep the air tanks drained they can have serious problems if the water gets into the transmission. The D13 is a good strong engine that gets decent fuel economy. Not sure what that was is set for but the standard settings are 455hp 1850ft pnds torque. Hope that helps you.","replyToPid":0}
发表于 2020-5-24 04:39:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Volvo engine are great engine ","replyToPid":0}
发表于 2020-5-24 04:38:24 来自手机 | 显示全部楼层
959279 发表于 2020-05-22 19:04:09 08 compared to 17 d13 is a different engine. Not comparable
","text":"That’s what I have a d13 engine. It’s the same engine. The 2017 has more sensors and def. it’s the same engine","replyToPid":376754}
发表于 2020-5-22 15:31:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Get all the maintenance records and there’s Service out there that’s like that Carfax for big trucks but I don’t know what the name of it is","replyToPid":0}
发表于 2020-5-22 23:17:53 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I drove 2 volvos both over 700k from new only issue I ever had was the def pump"}
发表于 2020-5-23 06:06:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"It doesn't really matter what you buy, especially newer truck. In time they will all give you some sort of problems.  I would get any and all maintenance records,  do an oil sample, if possible remove the valve cover and check for excessive soot build up.  If you can scrape soot off, I would pass on the truck.  If you take an oil sample and it comes back good....I would consider buying it.","replyToPid":0}
 楼主| 发表于 2020-5-22 19:32:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"thank you sir. great thing about this unit is that all maintenance was done by volvo so i did contact them and was told that NOX sensor and clutch work (did not specify) rest  was minor hose and some light fuses.","replyToPid":0}
 楼主| 发表于 2020-5-22 19:34:59 来自手机 | 显示全部楼层
101369 发表于 2020-05-22 07:31:37 Get all the maintenance records and there’s Service out there that’s like that Carfax for big trucks but I don’t know what the name of it is
","text":"any idea about the injectors and cup needing replacement after 500k? is that an issue all Volvos have or just some. youtube was filled with reviews about that.","replyToPid":376641}
发表于 2020-5-22 20:19:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s a Volvo ? ","replyToPid":0}
 楼主| 发表于 2020-5-22 21:20:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"lol yes","replyToPid":0}
 楼主| 发表于 2020-5-22 21:27:05 来自手机 | 显示全部楼层
962174 发表于 2020-05-22 13:24:15 No. and if it has a Volvo engine fück no.
","text":"yes it is a volvo engine. has 500K Miles in a great cosmetic condition over all","replyToPid":376682}
GMT+8, 2026-2-11 17:21 , Processed in 0.083838 second(s), 24 queries .
