查看: 43|回复: 0
2014 International ProStar
 楼主| 发表于 2020-5-22 04:08:11 来自手机 | 显示全部楼层 |阅读模式
mileageV2:
{"text":"For Sale Used 2014 Sleeper. This Truck Was Previously Owned By A Lease Fleet. We Have Access To The Maintenance Records Over Its Lifetime. This Sleek Low Roof Sleeper Has A 450 HP Cummins Motor And A Fuller RTLO-18913A 13-speed Manual, Double Overdrive Transmission Along With A 3.36 Gear Ratio For Just The Right Combination To Get The Best Power And Fuel Efficiency This Truck Includes The Following Standards And Features: Cab Interior Trim Premium, 56\" Low Roof Sleeper Cab, Air Conditioner With Integral Heater And Defroster, Set Up For Fridge. Radio AM/FM/WB/Clock/Bluetooth/USB Input/auxiliary Input, MP3, Apple Device Play & Control, With Multiple Speakers, Radio, Auxiliary Controls Located In Sleeper Control Panel; Includes Display And Controls For Radio Power, Volume, Mode, Seek/Tune, Clock And Alarm, Includes Power Source And Two Antenna Bases With Wiring, Steering Column Tilting And Telescoping,  Window, Power (2) And Power Door Locks, Left And Right Doors, Includes Express Down Feature,  Mirrors (2)  Aero Rectangular, Power Adjust, Thermostatically Controlled Heated Heads, Amber Lens Led Clearance Lights, Turn Signals, Bright Heads, Breakaway Type, 7\" X 16\", Integral Convex Both Sides, For 102\" Load Width, Seat, Driver Air Suspension, High Back, Vinyl Boxing With Cloth Facing, 2 Arm Rests, Isolator, 8.5\" Adjust, 3 Chamber Lumbar, 6 Way Front Cushion Adjust, 3 Way Rear Cushion Adjust, 6-23 Degree Back Angle Adjustment, Bellows, Non-swivel, Map Pocket,  Seat, Passenger Air Suspension, High Back, Vinyl Boxing With Cloth Facing, 2 Arm Rests, Isolator, 8.9\" Adjust, 1 Chamber Lumbar, 2 Position Front Cushion Adjust, 6-23 Degree Back Angle Adjustment, Map Pocket,  Cabinet, Overhead (2) Airline Type; 2 Right Side, With Single Bunk, Access, Cab Aluminum, Driver & Passenger Sides, Two Steps Per Door, Trailer Hoses And Cables Coiled, Nylon Hose, 15' Working Length, 24\" Tractor Lead Length, 6\" Trailer Lead Length, Aluminum Glad Hands With Rubber Seals, Lightning Cable With Nylon Plug,  Wheels, Front Disc; 22.5x8.25 Rims, Non-polished Aluminum, 10-stud, 285.75mm Bc, Hub-piloted, Flanged Nut, With Aluminum Hubs, Sunshade, Exterior Aerodynamic, Painted Roof Color, With Integral Led Clearance/marker Lights, Cab Side Extenders Fairings, Fuel Tank (2) Top Draw, Non-polished Aluminum, 26\" DIA, 100 Us Gal (379l); Total Capacity 200 Us Gal, With Dual Supply And Return Lines, Less Equalizer Line, Mounted Left And Right Side, Back Of Battery Box, Under Sleeper, PDL Warning Buzzer Power Divider Lock, Engine Block Heater, Fifth Wheel, Air Slide, Quarter Fenders For Rear Wheels, Mirror-finished Stainless Steel, Frame Mounted, With Over 120 Rush Truck Centers And Service Locations Nationwide To Keep You Up And Running. With Over 3000 Trucks In Stock We Have The Truck You Are Looking For. We Have Optional Extended Warranty And Finance Options Are Available With Up To 90 Days No Payments OAC. CALL TODAY TO MAKE AN OFFER","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":480.0,\"name\":\"\",\"url\":\"\",\"width\":640.0},{\"description\":\"\",\"height\":394.0,\"name\":\"\",\"url\":\"\",\"width\":700.0},{\"description\":\"\",\"height\":394.0,\"name\":\"\",\"url\":\"\",\"width\":700.0},{\"description\":\"\",\"height\":394.0,\"name\":\"\",\"url\":\"\",\"width\":700.0},{\"description\":\"\",\"height\":394.0,\"name\":\"\",\"url\":\"\",\"width\":700.0},{\"description\":\"\",\"height\":394.0,\"name\":\"\",\"url\":\"\",\"width\":700.0},{\"description\":\"\",\"height\":394.0,\"name\":\"\",\"url\":\"\",\"width\":700.0},{\"description\":\"\",\"height\":394.0,\"name\":\"\",\"url\":\"\",\"width\":700.0},{\"description\":\"\",\"height\":394.0,\"name\":\"\",\"url\":\"\",\"width\":700.0},{\"description\":\"\",\"height\":394.0,\"name\":\"\",\"url\":\"\",\"width\":700.0},{\"description\":\"\",\"height\":394.0,\"name\":\"\",\"url\":\"\",\"width\":700.0},{\"description\":\"\",\"height\":394.0,\"name\":\"\",\"url\":\"\",\"width\":700.0},{\"description\":\"\",\"height\":394.0,\"name\":\"\",\"url\":\"\",\"width\":700.0},{\"description\":\"\",\"height\":394.0,\"name\":\"\",\"url\":\"\",\"width\":700.0},{\"description\":\"\",\"height\":394.0,\"name\":\"\",\"url\":\"\",\"width\":700.0},{\"description\":\"\",\"height\":394.0,\"name\":\"\",\"url\":\"\",\"width\":700.0},{\"description\":\"\",\"height\":394.0,\"name\":\"\",\"url\":\"\",\"width\":700.0},{\"description\":\"\",\"height\":394.0,\"name\":\"\",\"url\":\"\",\"width\":700.0},{\"description\":\"\",\"height\":394.0,\"name\":\"\",\"url\":\"\",\"width\":700.0},{\"description\":\"\",\"height\":394.0,\"name\":\"\",\"url\":\"\",\"width\":700.0},{\"description\":\"\",\"height\":394.0,\"name\":\"\",\"url\":\"\",\"width\":700.0},{\"description\":\"\",\"height\":394.0,\"name\":\"\",\"url\":\"\",\"width\":700.0},{\"description\":\"\",\"height\":394.0,\"name\":\"\",\"url\":\"\",\"width\":700.0},{\"description\":\"\",\"height\":394.0,\"name\":\"\",\"url\":\"\",\"width\":700.0},{\"description\":\"\",\"height\":394.0,\"name\":\"\",\"url\":\"\",\"width\":700.0},{\"description\":\"\",\"height\":394.0,\"name\":\"\",\"url\":\"\",\"width\":700.0},{\"description\":\"\",\"height\":394.0,\"name\":\"\",\"url\":\"\",\"width\":700.0},{\"description\":\"\",\"height\":394.0,\"name\":\"\",\"url\":\"\",\"width\":700.0},{\"description\":\"\",\"height\":394.0,\"name\":\"\",\"url\":\"\",\"width\":700.0},{\"description\":\"\",\"height\":394.0,\"name\":\"\",\"url\":\"\",\"width\":700.0},{\"description\":\"\",\"height\":394.0,\"name\":\"\",\"url\":\"\",\"width\":700.0},{\"description\":\"\",\"height\":394.0,\"name\":\"\",\"url\":\"\",\"width\":700.0}]","canComment":null,"externalShare":false}
GMT+8, 2026-4-3 06:57 , Processed in 0.070674 second(s), 25 queries .
